High egts, lowboost, low power, lost of smoke.
#31
I spoke to Mitch at diesel auto power and he said that they can do a warranty upgrade I'd just have to pay the difference. He said the 64/68/12 would be a little bit better to handle everything while lowering boost because its a bigger charger and not sacrificing too much spool
#32
Too bad these are so expensive. BD Trackmaster Turbo Diverting Valve T-3-T4 Flange
#33
#34
I don't think you will gain much at lower rpms with water/methanol injection. At least not enough to make up for a big turbo. Why not use a VGT turbo and a stand alone controller?
#35
Got the turbo off last night and apparently I blew part of the wastegate apart... Takes 5 days for cap to get my turbo. Gonna upgrade it to a 64/68/12 wastegated and gonna wrap the downpipe while I have it off. Might try to wrap the manifold also and might get a turbo blanket.
#38
Just an update. I got the turbo warrentied. They didn't upgrade it but they put a different tail section on it that was set to open the waste gate at 42 psi. Since then everything is working perfectly and I was able to run the truck on the dyno here at englishtown at the diesel nationals. I hit 396 rwhp and 818 ft-lbs. What do I need to make 500hp? I have no fuel system or water meth yet And I know the water meth should boost me about 40hp.
#40
"not 100% sure" and "imagine" don't lend themselves to credible info that others who may be interested in your setup are seeking.
I like your dyno numbers - Mustang dyno?
Let's translate this into real world info for the folks considering your turbo setup -
What are your track times?
This is all just so the non believers don't attribute your HP #s to your "modded banjo bolt" setup contributing to your 1200rpm spool on a largish single.
#42
lgp9999
09-08-2007 11:19 PM
BCarmicle
09-22-2004 12:10 PM
