Headlight switch help
Im going the relay route that's been discussed here but I am having trouble getting the old switch out. How does the little triangle shaft and switch **** come off so I can get the old switch and trim plate off? Thanks.
Actually, I think the button is visible on the bottom side of the switch. It's easily palpable as a push button, and it releases the shaft. When installing the switch, the shaft is just pushed in until it locks.
You have to pull the dashboard face to remove the light switch. It's also helpful to pull down the parking brake release lever. Other than that, any disjointed undersized contortionist should have no trouble. I always schedule a chiropractor appointment after I work on one.
I need to pull the dash to work on the heater switching. I think I'll pull the ground wire for the headlamp switch through the dash backing and put it under a screw mounting the switch.
mtdoragary
11-07-2013 08:31 AM
jesse123
07-08-2012 09:04 PM
Barryn
07-14-2008 09:30 AM
jlipskoc
10-24-2005 01:16 PM
