he351cw questions
he351cw questions
I just finished up my 351 swap and have some questions about boost/egt. With my old HX35 at 70mph i was seeing consistent 7lbs boost and 700° on the Pyro. With the 351 in getting 6lbs boost 750°. What gives, i thought this 351 would see more boost and lower egts
I see about 6-8psi at 70 and 6-750EGT. Mash the throttle and then tell us the comparison.
You may also want to adjust your afc differently than the hx35 liked.
Wastegate is shut tight. Have not hit a high enough pressure yet to open it up to verify functionality. once i do i will adjust the boost elbow for the pressure i want. This turbo sure is quiet compared to the HX35. That one screamed every time i shifted. Can't even hear this one
The silencer ring still in?
I have a factory air box and a 4" DE. It is quiet without having the silencer ring.
I wouldn't sweat it. One of the reasons I bet money on for the 1lbs difference in regular driving is due to the larger and more efficient wheel. The 50* greater EGT may becoming from the open housing vs the divided/dual scroll housing of the HX.
All of that is negated at WOT when the HE351 cools better and supplies more air than the HX.
dzl_damon
07-28-2009 06:16 PM
jesussaves
0
04-21-2009 12:04 PM
PaulDaisy
09-13-2008 08:42 AM
