Getrag counter shaft
I'm working on overhauling the Getrag and have run into an issue with the counter shaft bearing race/cup spinning in the bore of the case, on the rear of the trans. Anyone have a fix for this or am I needing to use another case? I assume the preload will not keep the race from turning.
Loctite Application Case History - Great Ideas, since 1953 » Blog Archive » Loctite® 660 Retains Bearing to Gear Housing Reliably
Have used this stuff a fair bit when i was a HD mech in gearboxes.
thrashingcows (02-21-2017)
diesel cowboy
10-02-2015 08:10 AM
