Gas to diesel conversion.
Old 09-25-2016, 12:56 PM
A.Spagnuolo's Avatar
I have a 93 Cummins 2wd automatic. I was looking at a 92 w250 gas automatic. Would I need anything? Would transfer case work?
Old 09-25-2016, 02:23 PM
johnh's Avatar
yep!
Old 09-26-2016, 09:42 AM
patdaly's Avatar
To do it right you will need to take the guts from your diesel 2WD overdrive section and put them in the gasser 4WD one.
Technically you could just swap them, but the planetaries are beefier in the diesel one.
Old 09-26-2016, 03:01 PM
Received 1,332 Likes on 862 Posts
The gasser tranny is a lighter duty, and different bell housing, but if you combine the two...as long as the gasser tranny is a A518, or 727, then you should be OK. The lighter duty transfer case on the gasser tranny will work, but for how long is the question. There was a reason they used the grenade proof NP205 with the cummins.
mknittle (09-26-2016)
Old 09-28-2016, 08:03 AM
patdaly's Avatar
Did they use the NP241 in 3/4 ton gassers?
I thought it was only in the 1/2 tons.
Old 09-28-2016, 08:08 AM
Received 2,392 Likes on 1,576 Posts
I know I have seen some W-250 gassers with the NP-205.
USMC64-70
31
08-12-2009 11:46 AM
THURENfab.
08-08-2007 07:02 AM
Scovo1
30
05-11-2007 01:08 PM
04ctd
15
04-30-2006 08:45 AM
DieselMuskrat
03-25-2005 06:55 AM
Quick Reply: Gas to diesel conversion.
