Fummins
Old 09-30-2016, 02:55 PM
BHD
BHD's Avatar
Stuck lifters or broken camshaft could be culprits.
Old 10-02-2016, 02:33 PM
Rick 12v CTD's Avatar
If you didn't reset your valve lash correctly when you changed the HG you could have had a piston hit a valve which bent the pushrod. On the pistons with the bent pushrods I would check to see if the valves are bent as well. There's a good chance they are.
I don't see why a tappet would stick out of nowhere but anything is possible.
If the cam broke, it would have been caused by one of the timing case bolts or the dowel pin falling out and getting wedged between the gears.
Also, check to see if the crank gear has slipped on the crank. There is supposed to be a visible keyway locking it in place but I've seen the gear walk off the shaft enough to cause it to slip.
Old 10-03-2016, 09:23 AM
j_martin's Avatar
Looks to me like you tried to start it out of time and valves hit pistons. You're probably going to have to at least pull the head and replace bent valves, and maybe other damage as well.
Hoping for the best, but I'm afraid you just discovered that short cuts often have pit falls in them that totally wreck your day.
Rick 12v CTD
03-09-2011 12:13 AM
CharGriller
Cummins Conversions
18
01-31-2009 05:22 PM
Richie O
Cummins Conversions
09-28-2008 11:59 PM
wannadiesel
01-11-2008 12:55 PM
BigBully
12-12-2007 08:47 PM
Quick Reply: Fummins
