Fuel Tank Module/Sending Unit Source?
I believe I may have a cracked feed line in the sending unit with my 92 Dodge. It started a few weeks back. I would have an intermittent miss/stall/shutter. I checked all the normal stuff. Replaced the fuel filter. Checked/cleaned the FSS connections.
I don't go through a lot of fuel on my truck really. I fill it up every two weeks and use about 10-15 gallons every time. I thought I might have had some water/junk in the fuel last time this issue popped up. I topped the tank off and added some 911. All the problems went away. With the holidays I don't think I went though much fuel. The last time this happened the tank was down about 10-12 gallons. Now the tank is down another 10-12 gallons and the same issues popped up on the way home tonight.
Anyways.
Is there a source for the complete unit in the aftermarket? Looking around at the normal places I am not seeing much of anything.
Anyways.
I don't know of any stock style aftermarket ones, but I do have a few original ones on my shop shelf.
PM me if you would like to discuss buying one of them.
About 3 years ago I believe I got my fuel sending unit online thru Geno's Garage. I didn't have any engine problems...I replaced mine because the fuel gauge didn't function. Has worked well for 3 years+
I have a few still
Plumb (10-11-2021)
Hover over his name & it will highlight, then left click on it & choose send a private message.
Plumb,
Its may take a day or two before you can PM me as it looks like you just joined.
You can find me on CL [CraigsList] with adds in VT and NH. I am the add with all the 12V motors on rolling engine crates in a line. Just put Cummins in the search bar for CL in VT
klx650a2
06-01-2009 03:12 AM
