FAQ/Knowledge base "How do I...?" Look here first! A.K.A. "The Sticky"
Here is a link to the tech articles.
Pump instructions, part numbers etc. can all be found here
https://www.dieseltruckresource.com/...n&onlynewfaq=1
jthorpe (11-07-2010)
This is a thread to help people find info on common problems/mods without a lot of searching and reading. I realize that not everything is in here, this is only the beginning. If you see something that belongs in here, post it in the "Definitive Threads" thread. If you have a question that is not addressed in here, please post it in the "What do you need to know?" thread.
General Information
Head Bolt Torque 4BT & 6BT
https://www.dieseltruckresource.com/...torque-329686/
Basic specs for the 1st gen engine (along with some part #'s):
91 Ram engine specs
Fluid capacities:
https://www.dieseltruckresource.com/...d.php?t=204044
Model names explained (even I couldn't find a clear explanation doing a search ): Our trucks are all 250 (3/4 ton) or 350 (1 ton) rated. D-series trucks are 2wd, W series trucks are 4X4's. D350 = 2wd 1 ton.
Technical Service Bulletins:
https://www.dieseltruckresource.com/...s-t315813.html
Misc. part #'s:
More part #'s:
https://www.dieseltruckresource.com/...d.php?t=164612
Part Number changes and Special Notes:
https://www.dieseltruckresource.com/...d-t308871.html
2nd Gen wheels on a 1st Gen:
https://www.dieseltruckresource.com/...d.php?t=147764
3rd Gen wheel on a 1st Gen:
https://www.dieseltruckresource.com/...w-t255446.html
Block heater outlet install:
https://www.dieseltruckresource.com/...d.php?t=167831
How to post pics on DTR:
https://www.dieseltruckresource.com/...d.php?t=187910
91 Ram engine specs
Fluid capacities:
Misc. part #'s:
More part #'s:
Body
Glove Box LED Upgrade
https://www.dieseltruckresource.com/...e-t316712.html
Replace your ignition lock cylinder or ignition switch (Tilt column):
https://www.dieseltruckresource.com/...d.php?t=241339
Replace The Ignition Key Lock Cylinder On Non-Tilt Wheel:
https://www.dieseltruckresource.com/...r-t312883.html
A Look Inside Your Power Mirrors
https://www.dieseltruckresource.com/...r-t300928.html
Cowl crack fixes:
http://wiki.dieseltruckresource.com/wiki/Cowl_Fix
Commence Operation Silence: (How to insulate and soundproof your cab)
https://www.dieseltruckresource.com/...e-t287033.html
Door latch/handle repairs:
http://ramchargercentral.com/index.p...owtoshow;id=60
Floppy mirrors?
http://ramchargercentral.com/index.p...owtoshow;id=39
Window motor repair (also covers R&R):
https://www.dieseltruckresource.com/...d.php?t=100536
Window motor repair revisited - circuit breaker and brush replacement:
https://www.dieseltruckresource.com/...d.php?t=141605
Drilling crank window doors for power windows:
https://www.dieseltruckresource.com/...d.php?t=211811
Tailgate latch repair:
http://ramchargercentral.com/index.p...owtoshow;id=29
Clean out the HVAC box:
http://ramchargercentral.com/index.p...owtoshow;id=45
Clean out the HVAC box (with unique lid):
https://www.dieseltruckresource.com/...t-t298318.html
Removing the HVAC box (to change heater core or evaporator):
https://www.dieseltruckresource.com/....html?t=248580
Converting A/C to R134a:
https://www.dieseltruckresource.com/...d.php?t=107810
Renew your AC system:
https://www.dieseltruckresource.com/...m-t313221.html
In-Cab Air Cleaner Install
https://www.dieseltruckresource.com/...duster-330820/
Body/patch panel sources:
http://www.rustrepair.com/Dodge_pickup.htm
Poly cab mount bushings:
https://www.dieseltruckresource.com/...d.php?t=217491
http://store.shermanparts.com/cgi-bi...pickupchry.htm
Gauge cluster refresh:
http://www.dens-site.net/Dodge_CTD/Gauge_Cluster/
Odometer repair:
https://www.dieseltruckresource.com/...d.php?t=128685
Alternate source for odometer repair parts:
https://www.dieseltruckresource.com/...d.php?t=185945
Repairing gauge cluster lights:
https://www.dieseltruckresource.com/...r-t265366.html
2nd/3rd gen towing mirrors:
https://www.dieseltruckresource.com/...d.php?t=150798
Let's replace our wing window seals and how to remove the wing window assembly:
https://www.dieseltruckresource.com/...s-t313519.html
Replace your door and window weatherstripping:
https://www.dieseltruckresource.com/...d.php?t=152939
An insider's view of the doors courtesy of Jim Lane: With Part Numbers
https://www.dieseltruckresource.com/...d.php?t=218946
Emergency hood release cable install:
https://www.dieseltruckresource.com/...d.php?t=187435
How To Secure Your Tailgate:
https://www.dieseltruckresource.com/...296564p2.html?
Fix your vent window latch:
https://www.dieseltruckresource.com/...d.php?t=191213
Intercooled style grille install on a non-intercooled truck:
http://www.moparmusclemagazine.com/p...lle/index.html
How the speedometer drive works:
https://www.dieseltruckresource.com/...d.php?t=198123
Make your own interior shelf:
https://www.dieseltruckresource.com/...d.php?t=219993
Replace your saggy headliner:
https://www.dieseltruckresource.com/forums/showpost.php?p=1884178&postcount=5
Water on the driver's side floor?
https://www.dieseltruckresource.com/...t-t264729.html
2nd gen seats:
https://www.dieseltruckresource.com/...h-t276849.html
Seat Heaters.
https://www.dieseltruckresource.com/...s-t284720.html
Wiper-Arm Bushings:
https://www.dieseltruckresource.com/...s-t282912.html
Cowl crack fixes:
Floppy mirrors?
Odometer repair:
2nd gen seats:
Seat Heaters.
Wiper-Arm Bushings:
Brakes
Properly adjust your rear brakes:
Brake Adjustments & Pictures - Dodge Diesel - Diesel Truck Resource Forums
1 ton shoe conversion:
1st gen 3" brakes - Dodge Diesel - Diesel Truck Resource Forums
ABS diagnostic:
RWAL woes part2 - Dodge Diesel - Diesel Truck Resource Forums
Drum removal - also includes disc brake conversion (this is a D60, so don't take the conversion info as gospel - and none of the conversion kits work on duallys):
RamchargerCentral.Com - Articles - Dana 60 Rear Disc Brakes - Dodge Ram, Ramcharger, Cummins, Jeep, Durango, Power Wagon, Trailduster, all Mopar Truck & SUV Owners. Dodgeram
Rear disc conversions:
Rear Drum To Disc Brake Conversion - Dodge Diesel - Diesel Truck Resource Forums
http://www.off-road.com/toyota/tech/dana70discbrakes/
http://www.pavementsucks.com/tech/reardisk.php
4X4 front wheel bearing and brake service:
Rebuild your front D60 4x4 brakes (General) - Dodge Diesel - Diesel Truck Resource Forums
2wd front brake service and proper pad installation technique:
2wd front brake basics - and a tip on preventing brake noise. - Dodge Diesel - Diesel Truck Resource Forums
2WD Front Disc Brake Repair and Upgrade, Pt1
2WD Front Disc Brake Repair and Upgrade, Pt1 - Dodge Diesel - Diesel Truck Resource Forums
Where do I get a front hub nut socket that fits?
axle jam nut - Dodge Diesel - Diesel Truck Resource Forums
Fixing a grooved spindle without a speedi-sleeve:
Axle Speedy-Sleeve Alternative - Dodge Diesel - Diesel Truck Resource Forums
Fixing a grooved spindle with a speedi-sleeve (for when you've worn 2 grooves in it ):
How to repair a leaking axle seal. - Dodge Diesel - Diesel Truck Resource Forums
Rear hub service:
Service your Rear Bearings/Seals - Dodge Diesel - Diesel Truck Resource Forums
Braided stainless brake hose install:
Firm your brake pedal with wire braided hoses. - Dodge Diesel - Diesel Truck Resource Forums
Booster replacement:
Brake Booster Install - Dodge Diesel - Diesel Truck Resource Forums
Convert to Hydraboost:
Hydro boost units, who's got 'em? - Dodge Diesel - Diesel Truck Resource Forums
https://www.dieseltruckresource.com/...ml#post2582890
Write-up for installing 2nd Gen Hydroboost brakes on your 1st gen - Dodge Diesel - Diesel Truck Resource Forums
Adjust and repair the P-brake pedal:
https://www.dieseltruckresource.com/...-pedal-326280/
ABS diagnostic:
Rear hub service:
TMWeber (10-07-2018)
Steering and Suspension
Dually wheel centering procedure - mandatory reading for all dually owners!
https://www.dieseltruckresource.com/...s-t248980.html
2wd levelling (raise front end):
https://www.dieseltruckresource.com/...ad.php?t=93841
https://www.dieseltruckresource.com/...d.php?t=217632
2wd ball joints (also covers bearing service):
https://www.dieseltruckresource.com/...g-t265538.html
Steering coupler rebuild:
http://ramchargercentral.com/index.p...owtoshow;id=16
Borgeson shaft install:
http://ramchargercentral.com/index.p...howtoshow;id=7
Another one on the Borgeson with instructions on changing the input shaft seal:
https://www.dieseltruckresource.com/...9&postcount=23
Important note on steering shaft replacement: DO NOT spin the steering wheel with the shaft disconnected. Some of these trucks use a clockspring to run the horn and cruise, break it and it's about $150 to fix it. Tie the steering wheel to the seat frame before you disconnect the shaft.
Homebrew steering shaft:
https://www.dieseltruckresource.com/...d.php?t=93363-
Steering box bracket P/N:
https://www.dieseltruckresource.com/...20&postcount=1
Input shaft seal replacement:
http://ramchargercentral.com/index.p...owtoshow;id=93
Crunching/scraping noise inside the steering column?
https://www.dieseltruckresource.com/...d.php?t=182442
Add polyurethane spring tip bushings to improve your ride:
https://www.dieseltruckresource.com/...d.php?t=224332
Build new rear shock mounts (think Dana 80 or 3 bearing 14 bolt swap )
https://www.dieseltruckresource.com/...d.php?t=212944
Quick and dirty steering box adjustment - for a Jeep XJ but our box works the same way:
http://www.off-road.com/jeep/tech/po...ent-20047.html
Wheel hop fix -advanced fab skills required:
https://www.dieseltruckresource.com/...s-t274327.html
Replace/Renew DANA 60 4x4 king pins & seals:
https://www.dieseltruckresource.com/...4-t290373.html
Crossover Steering:
https://www.dieseltruckresource.com/...t-t291427.html
Steering Gear Retrofit:
https://www.dieseltruckresource.com/...2-t301769.html
Steering Coupler protector:
https://www.dieseltruckresource.com/...r-t303388.html
Crossover Steering:
Electrical
The Importance of Alternator Grounding (Explains why your lights dim when it is cold)
Alternator Ground - Dodge Diesel - Diesel Truck Resource Forums
It's not charging! ('92 & '93 trucks only)
wont charge - Dodge Diesel - Diesel Truck Resource Forums
What are all these wires doing on my mechanical engine?
(non-intercooled)
What are all these wires doing on my mechanical engine - the non-intercooled version - Dodge Diesel - Diesel Truck Resource Forums
(intercooled)
Help me ID these - pics inside - Dodge Diesel - Diesel Truck Resource Forums
Headlight relays:
Installing Headlamp Relays - Dodge Diesel - Diesel Truck Resource Forums
RamchargerCentral.Com - Articles - How to Install Headlight Relays - Dodge Ram, Ramcharger, Cummins, Jeep, Durango, Power Wagon, Trailduster, all Mopar Truck & SUV Owners. Dodgeram
Headlights no longer suck! - Dodge Diesel - Diesel Truck Resource Forums Shows how to have low beams on with the high beams.
Grid heater relay repair:
Denis Hruza - Dodge CTD - Grid Heater Solenoid Tune-Up
'91.5 wiring diagrams
Index of /Dodge_CTD/1991.5-Wiring_Diagrams
LED cab light conversion (now with light location diagram for new installs)
Update 1st. Gen to the 21st century - Dodge Diesel - Diesel Truck Resource Forums
LED turn signals and taillights:
LED turn and tail lights. - Dodge Diesel - Diesel Truck Resource Forums
How To Install LED Front Turn Signals (front corner lights will flash properly)
How to install Front LED Turn Signals - Dodge Diesel - Diesel Truck Resource Forums
Another LED Taillight Install:
Make your own LED taillights.. (enhanced Taillight version) - Dodge Diesel - Diesel Truck Resource Forums
'92 and '93 PCM power check:
The TPS & CPS/PCM VR Bypass Challenge. - Dodge Diesel - Diesel Truck Resource Forums
Converting the stock alternator to internal regulation:
NipponDenso Alternator Regulator - Dodge Diesel - Diesel Truck Resource Forums
Leece-Neville alternator install:
Leece Neville Alternator on a 6BT Cummins - Dodge Diesel - Diesel Truck Resource Forums
Install a Start Stop Switch
How to install a Start & Stop switch. - Dodge Diesel - Diesel Truck Resource Forums
Brake Light Switch Repair
Brake Light Switch Repair - Dodge Diesel - Diesel Truck Resource Forums
Rebuild your starter:
Rebuild Your CTD Starter - Dodge Diesel - Diesel Truck Resource Forums
NJTman's Starter Rebuild
https://www.dieseltruckresource.com/...photos-331359/
Replacing fusible links with fuses:
Fusible Link Abatement - Page 2 - Dodge Diesel - Diesel Truck Resource Forums
Adding a power distribution center:
Trailer lights isolation - Dodge Diesel - Diesel Truck Resource Forums
Put your blower motor on relays:
Blower motor - Dodge Diesel - Diesel Truck Resource Forums
Replace your blower motor and wheel using a GM unit
Replace your Dodge blower motor using a GM Blower Motor - Dodge Diesel - Diesel Truck Resource Forums
Weatherpack connector repair (oil pressure):
How to repair a weatherproof connector. - Dodge Diesel - Diesel Truck Resource Forums
Fix your Odometer!
https://www.dieseltruckresource.com/...r-long-128685/
Isspro tach wiring diagram:
Questions about hooking up a Isspro tach - Dodge Diesel - Diesel Truck Resource Forums
Use any tach you want to:
Gasser tach in a diesel - Dodge Diesel - Diesel Truck Resource Forums
Tach install and moving the OD button to the shifter:
Let's Screw-Up Your Steering Column With A New Tachometer and Gear Shifter! - Dodge Diesel - Diesel Truck Resource Forums
Factory tach harness diagrams:
OEM Tach wiring diagram - Dodge Diesel - Diesel Truck Resource Forums
Fix a burnt out OD indicator light:
Overdrive Indicator Light - Dodge Diesel - Diesel Truck Resource Forums
Replace your dash lights with LED's:
DIY: LED gauge cluster lights - Dodge Diesel - Diesel Truck Resource Forums
Instrument cluster refresh and LED conversion:
Repairing your instrument cluster & install LED's - Dodge Diesel - Diesel Truck Resource Forums
Halo ring (key light) bulb replacement:
key light ? - Dodge Diesel - Diesel Truck Resource Forums
Cruise switch pinout:
cruize control question - Dodge Diesel - Diesel Truck Resource Forums
89-91 Voltage "pulsing" issue solved!:
89-91 Voltage "pulsing" issue solved! - Dodge Diesel - Diesel Truck Resource Forums
Alternator 101:
Alternator 101 - Dodge Diesel - Diesel Truck Resource Forums
(non-intercooled)
(intercooled)
Headlight relays:
Fix your Odometer!
Alternator 101:
Drivetrain
Super Duty Transmission Oil Cooler:
https://www.dieseltruckresource.com/...r-t264993.html
TPS adjustment:
http://www.pdrdiesel.com/oldsite/Tech1GTPS.htm
http://dens-site.net/Dodge_CTD/tps-adjust.jpg
Replacing the TPS with a potentiometer:
https://www.dieseltruckresource.com/...ad.php?t=42003
Another writeup, but with pics:
https://www.dieseltruckresource.com/...d.php?t=142641
Use a 3.0 liter V6 TPS instead of the $200 CTD TPS:
https://www.dieseltruckresource.com/...d.php?t=202697
Controlling OD using governor pressure:
https://www.dieseltruckresource.com/...d.php?t=156988
TV/kickdown cable adjustment:
http://dens-site.net/Dodge_CTD/Kickdown_Adjustment/
Band adjustment/line pressure adjustment:
https://www.dieseltruckresource.com/...e-t265745.html
NV5600 swap info:
https://www.dieseltruckresource.com/forums/showpost.php?p=1074216&postcount=29
NP 205 tranfer case rebuild:
http://www.okcnetworks.com/bronco/205/np1.htm
2nd gen auto (47RH) into a 1st gen:
https://www.dieseltruckresource.com/...d.php?t=114702
https://www.dieseltruckresource.com/...d.php?t=236738
Axle vent cleanout:
https://www.dieseltruckresource.com/...d.php?t=115036
Getrag overfill/fluid level sight glass/temp probe install:
https://www.dieseltruckresource.com/...d.php?t=141280
Getrag shifter operation explained:
https://www.dieseltruckresource.com/...d.php?t=148533
Repair a broken Getrag shift lever:
https://www.dieseltruckresource.com/...x-t250129.html
Getrag rebuild info:
https://www.dieseltruckresource.com/...a-t265122.html
Automatic trans build:
https://www.dieseltruckresource.com/...d.php?t=160276
https://www.dieseltruckresource.com/....php?p=1991156
Fix a sloppy shifter (auto):
https://www.dieseltruckresource.com/forums/showpost.php?p=1717737&postcount=3
Shut up that rattling 4X4 shifter:
https://www.dieseltruckresource.com/...d.php?t=177579
Replace front axle U-joints:
https://www.dieseltruckresource.com/...d.php?t=187074
Getrag bearings, races and seal part numbers:
https://www.dieseltruckresource.com/forums/showpost.php?p=2663861&postcount=1
Dana axle rebuild info:
https://www.dieseltruckresource.com/...ml#post2774975
Turn your non lockup 518 into a lockup on the cheap
https://www.dieseltruckresource.com/...p-t318014.html
A518 46RH Overdrive Solenoid Replacement
https://www.dieseltruckresource.com/...cement-331103/
TPS adjustment:
NV5600 swap info:
Axle vent cleanout:
Engine
Troubleshooting and repair videos:
Check this out. - Dodge Diesel - Diesel Truck Resource Forums
Head Bolt Torque 4BT & 6BT engines:
Valve adjustment:
B Series Valve Adjustment
How to Adjust Your Valves - Dodge Diesel - Diesel Truck Resource Forums
KDP repair:
http://www.pavementsucks.com/forums/...hp?topic=70419
KSB diagnosis (applies to intercooled only):
KSB Questions - Dodge Diesel - Diesel Truck Resource Forums
Fuel filter change:
How do I replace my fuel filter? - Dodge Diesel - Diesel Truck Resource Forums
Fuel heater now obsolete and unavailable - replace it with a 2nd gen unit instead:
1Gen preheater - Dodge Diesel - Diesel Truck Resource Forums
Where's the thermostat gasket?
t-stat lift hook - Dodge Diesel - Diesel Truck Resource Forums
Fan belt routing diagram
Burning A/C Compressor - Dodge Diesel - Diesel Truck Resource Forums
Fan support hub bearing replacement:
Fan Clutch Bearing - Dodge Diesel - Diesel Truck Resource Forums
Oil pressure sender replacement
“Oil Pressure” - Dodge Diesel - Diesel Truck Resource Forums
Trouble codes
'92 and '93 Trouble codes - Dodge Diesel - Diesel Truck Resource Forums
Fix your torn fuel shutoff solenoid plunger...
Fix your fuel cut-off solenoid - Dodge Diesel - Diesel Truck Resource Forums
...or install a pull cable shutoff:
Pull Cable Manual Fuel Shutoff install and keeper - Dodge Diesel - Diesel Truck Resource Forums
Easy injector removal tool:
How to remove stubborn injectors easy ! ! ! ! - Dodge Diesel - Diesel Truck Resource Forums
Injector Swap:
My injector swap.... - Dodge Diesel - Diesel Truck Resource Forums
VE injector pump parts diagram:
Bosch VE Distributor Injection Pump - Dodge Diesel - Diesel Truck Resource Forums
Repairing a leaky control valve on the VE pump (with VE exploded diagram and parts list):
Injector-pump Drip Drip Drip Drip - Dodge Diesel - Diesel Truck Resource Forums
Repairing a leaky governor shaft and fuel screw:
How to repair a leaking Governor Shaft and Fuel Screw - Dodge Diesel - Diesel Truck Resource Forums
Repairing a leaking fuel pin:
Repair leaking fuel pin. - Dodge Diesel - Diesel Truck Resource Forums
Complete injector pump reseal:
VE rebuild with pics Look inside - Dodge Diesel - Diesel Truck Resource Forums
Installing the front crank seal the easy way:
Quickly and CORRECTLY install your front crankshaft seal - Dodge Diesel - Diesel Truck Resource Forums
Throttle shaft bushing part number:
Throttle shaft bushing part # - Dodge Diesel - Diesel Truck Resource Forums
Bellcrank bushing upgrade:
Bellcrank bushing upgrade - Dodge Diesel - Diesel Truck Resource Forums
How does the injection pump work? (an oldie but a goodie)
3000k Governor Spring - Dodge Diesel - Diesel Truck Resource Forums
How the injection pump works - this time with diagrams
Robert Bosch VE Pump Operation - Dodge Diesel - Diesel Truck Resource Forums
More injection pump info:
Bosch VE Pump - Dodge Diesel - Diesel Truck Resource Forums
Replacing the thermostat:
Replacing the Thermostat and Gasket - Dodge Diesel - Diesel Truck Resource Forums
Injection pump replacement:
Recall #605 Diesel Fuel Injection Pump
Videos! Pulling the IP - Dodge Diesel - Diesel Truck Resource Forums
Head gasket replacement:
Replace Your 12v CTD Head-Gasket - Dodge Diesel - Diesel Truck Resource Forums
Replace your motor mounts:
Replace Your Tired Engine Mounts - Dodge Diesel - Diesel Truck Resource Forums
Get the right motor mounts:
1st Gen Motor Mount ID - Dodge Diesel - Diesel Truck Resource Forums
Vacuum pump rebuild (non-intercooled style):
What happens when your vacuum pump stops working. - Dodge Diesel - Diesel Truck Resource Forums
Vacuum pump rebuild (intercooled style)
Intercooled style vacuum pump rebuild - Dodge Diesel - Diesel Truck Resource Forums
'89-'91 vacuum pump(s) to '91.5+ vacuum pump
https://www.dieseltruckresource.com/...m-pump-321123/
Changing valve springs:
Upgrade Your Valve Springs - Dodge Diesel - Diesel Truck Resource Forums
Cam and lifter replacement:
Replace Your Camshaft, Lifters 'n Stuff . . . . - Dodge Diesel - Diesel Truck Resource Forums
Fix a broken AFC line or AFC banjo bolt:
Broke a screw but beat a powerstroke - Dodge Diesel - Diesel Truck Resource Forums
Accessing that blasted idle locknut:
Fast Idle advice for a noob - Dodge Diesel - Diesel Truck Resource Forums
Easier access to idle adjustment (minor fab work required):
Easy idle adjustment. - Dodge Diesel - Diesel Truck Resource Forums
Extra crankcase venting:
The pressure's been building and I've got to vent . . .. - Dodge Diesel - Diesel Truck Resource Forums
Rear main seal replacement:
Rear Main Seal Install - Dodge Diesel - Diesel Truck Resource Forums
Coolant change - with engine block flush by Jim Lane:
Tips on changing coolant? - Dodge Diesel - Diesel Truck Resource Forums
Coolant filter install:
How to install a Coolant Filter - Dodge Diesel - Diesel Truck Resource Forums
Injection pump rebuild:
Getting those 3 sided bolts out of the VE pump:
https://www.dieseltruckresource.com/...ml#post2822314
Pump rebuild videos:
VE Injector Pump Installation Video - Dodge Diesel - Diesel Truck Resource Forums
Turbo rebuild (HX-35 but our WH1C is very similar):
Holset HX35W Rebuild Thread - Dodge Diesel - Diesel Truck Resource Forums
Turbo R&R:
H1C to WH1C how to change with pics - Dodge Diesel - Diesel Truck Resource Forums
Torque specs:
Engine torque specs? - Dodge Diesel - Diesel Truck Resource Forums
Anti theft Engine Immobilizer:
Anti Theft Engine Immobilizer you can make for less than a penny - Dodge Diesel - Diesel Truck Resource Forums
VE Pump Stand:
>>> my ve pump stand <<< - Dodge Diesel - Diesel Truck Resource Forums
Valve adjustment:
KDP repair:
Fuel filter change:
Trouble codes
Injector Swap:
Turbo R&R:
Torque specs:
VE Pump Stand:
Performance
Runaway info - READ BEFORE TWEAKING THE POWER SCREW!
https://www.dieseltruckresource.com/...d.php?t=158962
Build a Simple Tool To Stop Runaway
https://www.dieseltruckresource.com/...y-t297596.html
VE pump adjustments:
http://dodgeram.org/tech/dsl/more_power/Power_ve.htm
VE pump tweaking videos:
https://www.dieseltruckresource.com/...ml#post2596889
Some good pics of the insides of the AFC:
https://www.dieseltruckresource.com/...d.php?t=211443
Fuel screw pics:
https://www.dieseltruckresource.com/...d.php?t=153598
Fuel pin grind:
https://www.dieseltruckresource.com/...d.php?t=154086
Fuel pin info:
https://www.dieseltruckresource.com/...d.php?t=169225
Regaining AFC control after grinding the AFC lever:
https://www.dieseltruckresource.com/...d.php?t=217660
3200 RPM spring install:
http://dens-site.net/Dodge_CTD/Gover...ing/index.html
3200 RPM spring install video!
https://www.dieseltruckresource.com/...ml#post2851094
BHAF mount:
https://www.dieseltruckresource.com/...sort=1&cat=500
https://www.dieseltruckresource.com/...sort=1&cat=522
BHAF adapter:
https://www.dieseltruckresource.com/...d.php?t=176190
BC847's stock pot air box:
https://www.dieseltruckresource.com/...ight=stock+pot
Homemade intake duct:
https://www.dieseltruckresource.com/...d.php?t=115802
Piston pump install:
https://www.dieseltruckresource.com/...ad.php?t=93722
2nd gen piston pump upgrade:
https://www.dieseltruckresource.com/...d.php?t=176472
Bump the timing?
https://www.dieseltruckresource.com/...50&postcount=5
Timing using a dial indicator and adapter - on a VW VE but the procedure is the same for our trucks. 1.6 - 1.8 mm is a good place to start.
http://vwdieselparts.com/injtim.htm
HTT compressor upgrade instructions:
https://www.dieseltruckresource.com/...d.php?t=112422
Homebuilt hybrid:
https://www.dieseltruckresource.com/...d.php?t=215919
3" crossover pipe (non-intercooled engines)
https://www.dieseltruckresource.com/...d.php?t=118102
Homemade 4" downpipe:
https://www.dieseltruckresource.com/...e-t264047.html
Longer fuel filters:
https://www.dieseltruckresource.com/...6&postcount=16
Bigger fuel supply lines:
https://www.dieseltruckresource.com/...d.php?t=151190
Non-intercooled version:
https://www.dieseltruckresource.com/...d.php?t=174241
Valet Switch install:
https://www.dieseltruckresource.com/...&postcount=226
Wastegate divider removal:
https://www.dieseltruckresource.com/...289#post555289
PowerStroke intercooler install:
https://www.dieseltruckresource.com/...d.php?t=149268
2nd gen Dodge intercooler install on a non-intercooled truck:
https://www.dieseltruckresource.com/...d.php?t=186908
Keep your intercooler boots on:
https://www.dieseltruckresource.com/...d.php?t=240579
Head stud install:
https://www.dieseltruckresource.com/...d.php?t=213091
Fluidampr Install:
https://www.dieseltruckresource.com/...s-t316489.html
Understanding VE pump operation:
http://mebonty.monobasin.net/vepump.html
Deep thoughts on the VE:
https://www.dieseltruckresource.com/...03&postcount=1
P-Pump swap:
https://www.dieseltruckresource.com/...s-t263211.html
Dynamic Timing Spacer Install:
https://www.dieseltruckresource.com/...d-t318397.html
Fuel screw pics:
Fuel pin grind:
Fuel pin info:
BHAF mount:
BHAF adapter:
Bump the timing?
Homebuilt hybrid:
Head stud install:
Fluidampr Install:
P-Pump swap:
DTR Founder
You guys are great at technical articles on this site. It's very much appreciated. I'm still going to add this stuff to the wiki, but I will not be getting rid of your sticky threads. After some time mulling it over, I've made the decision just to leave it alone. The wiki can serve as a place for new users to search for and get information, but I know the effort you all put into this was huge. It's great info and it's appreciated.
BigDan
22
11-05-2006 09:29 PM
JaimeZX
05-12-2004 11:36 PM
