D250 Conversion to 4x4
Thinking about converting my 1989 D250 727 auto to a 4X4, but I don't have a donor at this time. What 4X4 truck would be the best donor? .....while maintaining my 727 auto.
The Dodge Cummins trucks came from the factory with the 727 from '89-'91.0.
If you want the donor truck to have a 727 you would want one from those years.
The gasser 727 is different that a diesel 727.
You might be able to find a W-250/W-350 gasser with the right 23 spline NP-205 though.
I am assuming you also want a W-250/W350 for the 4x4 frame for all the front suspension and the Dana 61 front axle.
You would need to get a '89-'91.0 Cummins powered truck to get that "rare" 3.07 axle gearing, to match your rear axle, that ONLY came in the '89-'91.0 AUTO Cummins trucks.
Received 1,637 Likes
Mr. J
There are at least a dozen other conversion to 4x4 threads fully detailed with instructions on how to convert a 2wd to 4wd, transmission , frame, suspension and other requirements for doing so. They even have pictures to follow along.
Look in thrashingcows or mknittle threads and step by step process will be revealed. As Oliver described, You need a 250 or 350 series donor, as the 150 series parts or frame memberscan't support the torque or weight of the engine, at least not for very long before failing
Make sure you photograph, document, and share your conversion with everybody. Most of all, have fun doing it.
mknittle (12-01-2016)
Yes it was an option that COULD be special ordered from the factory, but I have only seen ONE factory Getrag truck with 3.07s in my life. I have seen / owned quite a few 1st gens over the years.
I was just trying to help him find the right parts for his swap. Too much info tends to confuse people sometimes. He needs a 4x4 727 and a 3.07 geared front axle, his best bet is a '89-'91.0 auto Cummins truck…Right?
Good luck finding a 5 speed 4x4 donor truck with 3.07 gears.
I was waiting for someone to call me out on that.
oliver foster (12-01-2016)
bigragu
08-15-2006 07:16 PM
TexasHardcore
08-29-2004 12:20 AM
