Crew Pictures
Old 12-01-2016, 08:36 AM
  #196
twostep's Avatar
Originally Posted by gyman98
The vin is the best way. Pop out the glove box and see where the abs module and heater motor resistor is installed. If the resistor is in the cowl that's 93 style, in the hvac box is 85 style. Front Door panels changed in 87 up to and including 93.
If it's a manual trans see if the bulkhead has been moved over 3/4". Auto trans see if the clutch hydro hole is in the firewall and bracket holes are on the column support
Good info, thanks! I have some cell pics of the interior but the quality isn't the best. I could tell that the front doors are power windows and the back doors are manual which of course doesn't jive.
Old 12-01-2016, 09:12 AM
  #197
gyman98's Avatar
Actually it doesn't mean anything, even factory crew cabs with power windows always had power windows in the front only
Old 12-01-2016, 09:28 AM
  #198
twostep's Avatar
Again, great info. Thanks!
Old 03-17-2017, 06:54 PM
  #199
Azzie's Avatar
My first project
Found a NI CTD 5.9. A518 4x4 w/ NP205 to drop in. Starts this spring, or when I get it all together. Lot of parts, especially when you don't know what you're doing.
Old 03-17-2017, 08:14 PM
  #200
RamGuy84's Avatar
Crewcab's are simple to do. just take your time .Being you already have a 60 and you have 4x4 that's a good start.the rest is Simple .
Old 03-18-2017, 04:33 AM
  #201
KRB
KRB's Avatar
Sweet!
Is that a '72, 73 or 74?
Old 03-18-2017, 07:46 AM
  #202
Received 2,385 Likes on 1,575 Posts
It has a '78 grille in it.
That is a one year only grille style that came with the orange marker lights.
Old 03-18-2017, 08:33 AM
  #203
BHD
BHD's Avatar
'77 had the clear markers in the same location.
Old 03-18-2017, 08:41 AM
  #204
Yes the '77 has clear markers with orange bulbs. The '78 has orange markers with clear bulbs. The '78 grille is my favorite. I think it is something about the way the rectangular orange marker lights in the grille look on the orange '78's I have had.
Old 03-18-2017, 10:48 AM
  #205
Azzie's Avatar
I learned to drive in a 1978 Dodge short box my dad order with a 360 and heavy rear springs. Been trying to find a pick. My boy wanted to build a truck and I found this. 17,000 miles and the build sheets were in the rear seat springs. Thanks. Love that 78 grille and trying to keep it looking like this.
Old 03-19-2017, 05:52 AM
  #206
KRB
KRB's Avatar
But it has the fuel tank behind the back seat and a fulfloating front axle, I thought that all changed after '74?
Old 03-19-2017, 08:11 AM
  #207
Good point KRB.
I know my friend's sweet '76 Crew cab has the suicide rear tank behind the seat.
The Govt. bought most of those crew cab. I have seen lots of mismatched year parts on the old Govt. crews.
I have a '73 crew cab that has a strange manual '60 steering box and a drum braked, manual hub'ed, closed knuckle Dana 70 front axle.
I think on the govt. trucks, Dodge really just threw whatever leftover parts where around to fill the order.
All I know is that is a '78 grille and turn signal set up...the rest could be a mix up of '70's parts.
Old 03-19-2017, 08:24 AM
  #208
KRB
KRB's Avatar
Very true about the government trucks.
I have an old navy crew, '76 with the tank under the bed. Who knows how it came from the factory...
And my '76 M880 is actually a '77 and it is registered as a '76 sedan...
Old 03-19-2017, 08:48 AM
  #209
Azzie's Avatar
The nomenclature on tag says it has a Dana 44 in front. Mine has Dana 60. It was a true govt contract truck but not m880. It is very confusing because there are other little things that don't add up. The truck is very solid but needs TLC. I excited to get started now that wrestling season is over.
Old 03-19-2017, 09:44 AM
  #210
BHD
BHD's Avatar
My '77 regular cab had the suicide tank in the cab and a tank under the bed, with all the factory harness for dual tanks.
Trebor
09-13-2011 08:55 AM
Tyler_02
06-01-2009 07:38 PM
Banzai Bob
03-03-2009 01:22 AM
Timberline
03-04-2003 07:04 PM
Tom Bolitho
12-07-2002 09:30 AM
Quick Reply: Crew Pictures
