aftermarket speedo - auto trans
Justin there was no link in your first post. When you go to summit and put in summit speedo. It only comes up with about 10 or more universal style speedo's. That's why I asked. So I was on the same page with what you had.
The rear axle sensor is a 8K pulse on that truck. So you have options of using whichever is the easiest to wire in.
I assume your doing away with anything dealing with PCM control.
If the PCM doesn't see the injectors/ mass air sensor and other items. Its going to throw massive error codes. In this case dumping the PCM completely might be the best option. I dought if the PCM will turn on the ASD relay.
A was not mad or anything. I just needed a little more info to try and help more. No big deal.
sorry that this has gotten off 1st gen topic. was initially asking in this section as it is a 1st gen motor/trans and the trans signal was what i was questioning.
philip. do you know the pulse rate of the a518 signal? I guess worst case i could just calibrate the speedo to that if the abs sensor goes haywire.
Justin if you have a FSM for that truck. Scan the gasser wiring section and send it to me at philip1952@hotmail.com.
I have a FSM for a 05 model. I don't know how much difference there is between those years.
DodgeDiesel61
06-03-2008 07:50 PM
I PASS GAS
03-16-2006 07:59 AM
royta
08-16-2005 08:02 AM
