AC compressor rapid cycling 98 dodge causes?
My AC quit working on 98 dodge ram 3500. I checked Freon and the low side seemed to be within the range posted on the chart that went with the gauges. The compressor comes on but only stays on for about 2 or 3 seconds then cuts off. You can see pressure climbing on high side when running but it doesn't get very high before compressor cuts off and it drops back. AC blows hot air. Anything else other than low Freon that can cause this?
Follow the diagrams and probe the wiring through the control and limit switches to find the one that's opening and closing in step with the compressor cycling.
Another way is to bypass the low side and high side pressure switches one at a time to find which one is bad.
I think there's a temp switch on the evaporator that could also be bad.
What are your pressures exactly; especially when the compressor is on? If the freon is low, it may show normal pressures with the compressor off; then once it kicks on it may pull the pressure down on the low side to 20 or less. Low freon.
Low freon, #1 cause of this. Probably leaky evaporator knowing these trucks.
Ok, I rechecked the ac pressures today. It was 65 degrees outside. I got 25 psi initially on low side and 50 on high side with ac set on high. The compressor would not come on now. I jumped a wire across the low pressure switch and the compressor started running and stayed on. I got the pressure up to 35 psi on the low psi side. I stopped to check the high side and only had 75 psi then, still with the compressor turning. Still not cooling. High pressure is too low still. Compressor is not making any noise as far as I can tell.
Knowing 2nd gen trucks, you probably have an evaporator leak.
Low side should be 25-40 with the compressor running; High side at least 150; depending on how much air is moving thru the condenser.
I know what you mean about the evaporator. I have already replaced it a few years ago on this truck and just finished putting one in on my 2010 dodge 2500. I can try putting some more Freon into it and see what happens. It's better than replacing compressor. Then, if it leaks down again I will know. It was working when I took it to a repair shop for something else and then was not when I got it home. I wondered if they let some Freon out so I would have to take it back for the AC.
CTD2001
04-16-2010 01:03 PM
Coaldigger
09-24-2008 03:05 PM
MRuskow
10-24-2007 11:31 AM
kawi600
06-04-2006 03:13 PM
