93 W250 only 19 k miles
#32
Hey, on the 3rd pic down, what is the black vertical box with the corrugated hose? To the left of the transfer case? Again, nice find on that rig. Makes me wonder, as I am weird about thinking of stuff like this: you all ever wonder, say around 20 -30 years from now who will end up with our rigs? Take BC847's truck, or Jim Layne's rigs. 20 years from now, wether it be here on DTR, or another forum, what would others say about our rigs as some zit faced kid is posting pics of his new find? That zit faced kid isn't even born yet, so work with me on the imagine game
#33
I found that when I was checking lights. And had the flashers on their was a relay clicking sound . All the wiring is sound well connected but I told my son we need to take our time removing these things kinda like surgery don't wanna kill the patient lol
#34
Yeah the original owner was wwwll pilot he had added some rather interesting items. As far as we can tell it looks like a water heater???? It has a 1/0 batter cable running to it no idea what water it was heating. The pass side has an sux battery and air comp for the air horns. And weirdest one we found so far is a electrical box full of old relays that run to the trailer plugs (2).
In other words, you should think about what you're removing.
#35
At least I know what you think of my trailer lighting relay setup. Takes the load off the already overloaded dodge wiring, adds a layer of electrical fire safety, and also adds a layer of redundancy. (That means if something shorts out, it don't take out the whole rig.)
So it looks like the relay box is desired for trailers. I must read more here. We are studying the headlight relay system it's awesome that the thread is so detailed.
But now I'm wondering if maybe some of the added on wiring and relays on my sons truck (including under the hood) are related. I/my kid need to make this priority. Nonetheless really starting to appreciate what this truck truly is.
#36
Ahhh that makes a lot sense the more I learn about these trucks the better I'm understanding the electrical sys leaves a lot to be desired.
Headlight relays and the accompanying properly sized wiring (original headlight grounds are long and 18 or 20 gauge) really help. Same goes for 1 or more relays in the heater controls. If it's a 1 ton, a relay in the clearance lamps is good, too.
My trailer wiring has a 60 amp feed to the box under the bed, and from there a 40 amp 8 gauge, relay controlled power circuit, and relay controlled circuits for tail, turn, and backup lights. All are properly fused, of course.
A short in trailer wiring will take out a fuse in the relay box, instead of the entire flasher circuit. If it's turn signal short, it'll only take out one side.
I've seen entire rigs burn down to the ground with unprotected battery to battery wiring through the 7-way trailer connector.
#37
Nice. Other the a bit of dirt... Relatively clean.
The front springs Are reverse arched. Truck will ride much nicer once you rebuild them.
My personal experience was that I replaced them, then within a year has them back out again, rebuilding the replacements.
I wish I had just pulled the oem ones and had them rebuilt, replaci g the main leaf with a new, .such thicker unit. Lots of threads here about springs, and you'll get lots of opinions on this. Search it. You'll be surprised.
armourbl
13
04-24-2008 11:09 AM
Vividracing
07-30-2007 12:56 PM
BAJA MAN
26
12-25-2005 09:29 AM
dodge2000
14
06-24-2005 06:10 PM
