1992 W250 Resurrection/Modding
#33
Your truck has the same paint scheme as mine, I am rebuilding mine slowly, my cab is not worth saving so I found another. Then I got a sweet deal on a front clip. It just takes time. Make a plan, write it down, prioritize it so that funds are focused on the needs at hand.
#34
I got the twin stick adjusted how I want it. Now I need to pull the shifter sticks themselves out and get them powder coated. I am half way through the process of killing the KDP. The good news is that my KDP is right where it belongs and hasn't moved.
#37
#38
One of the benefits of the twin sticks are it is easier to shift. That alone has got to be worth something.
#40
I know mine in the crewcab is almost friggin impossible!! Moving or not.
#41
Good spring actuated hubs help too.(sorta like being in two places at one time) I hated my old Selectros on my Chevy(worm gear actuated) Sometimes You had to rock the truck back and forth just to get the hubs locked.
#42
Transfer case is newly rebuilt. Cleaned up the rails, and new ***** and springs. Should shift smooth as silk in my mind anyways....
Someone should engineer up an old hurst shifter to use as a TC shift mechanism. Then you could have the easy of a twin stick...on a single shifter. Hmmmm....goes outside to look for old shifter parts.....
#43
Mine goes in and out of gear pretty well now! It isn't quite smooth but has a nice positive feel when shifting. The only odd thing is that the front axle shifter has about twice the throw of the rear axle shifter.
#44
I finished tabbing the KDP, put everything back together and realized I forgot to put the dust seal on the end of the crankshaft. I guess I know what I'll be doing tomorrow.
#45
I made some home made air filter nuts out of 1/2" wing nuts and 1/4" coupler nuts that I welded with a torch. The welds aren't the best but that's what I get for being too lazy to set up the mig welder. Maybe overkill but was probably easier and cheaper than trying to find the OEM plastic nuts. And I painted them yellow!!
