1991 w250 low idle
Old 06-28-2015, 08:37 PM
A.Spagnuolo's Avatar
1991 w250 low idle
My truck is non i/c. When start up after has set over night or is cooler outside it will idle low and get white/grey smoke out of exhaust. Runs ok when rev up and seems to go away after just a little bit when revving. I replaced injectors recently seemed to help some. I have different fuel pin and 3200 gov spring. Truck has 250,000-300,000 miles (not sure odometer was not working when i got). As far as i know injection pump has never been rebuilt.
Does injection pump need rebuilt?
Thanks
Old 06-28-2015, 08:48 PM
Received 1,637 Likes on 1,112 Posts
Check to make sure your KSB is functioning properly.
Low idle ( and needing to b rebuilt ) is usually a sign after the engine is hot in warmer weather.
Rebuilding the IP is a maintenance thing @s all,of them eventually need it
Old 06-28-2015, 09:51 PM
j_martin's Avatar
White smoke is a big clue. Look for an air leak or bad lift pump. That fault will both drop fuel prime when sitting, and cause difficult start and white smoke.
KSB doesn't make much difference above about 40°.
Old 06-29-2015, 08:22 PM
ksb is ok. lift pump is 3 months old but i guess could be bad.
jd.goodwin
1st Gen All Products
0
03-22-2015 06:26 PM
bimmerboy86
03-02-2007 01:40 AM
AFK
08-17-2006 09:24 AM
redwake9112
08-09-2006 03:11 PM
91.5CTDBanks
08-08-2006 09:37 AM
Quick Reply: 1991 w250 low idle
