1980 Dodge Crew Cab
So the 91-93 have a PCM? I thought everything up to 98 1/2 was completely mechanical, after that the electronics started taking over?
Can I run a 91-93 engine without an intercooler?
Engines are fairly common, but they don't always come with all the parts necessary to complete an installation, Might actually make the install a lot trickier if you just have an engine plopped down in front of you and no idea what parts you need to add to get the whole system up and running. Thats my only hesitation on buying a motor already pulled from a truck.
Thanks again
Thanks again
ii) I don't see why you couldn't, although you'd need to change a few things like the intake tubing to go directly from the compressor outlet. Should be able to find one of those reasonably easily. My question is, why would you want to?
Or is it mandatory that the dash gauges be swapped over to keep the electronics working.
The reason I ask is I found a complete 1993 Cummins engine for sale but no intercooler and I'm pretty sure the Dash isn't there as well, but apparently the wiring harness is. Not how much of the wiring harness is there.
You can also wire up an external VR and the alternator will work. The cruise function of the PCM is probably easy enough to bypass as well.
Cool!
All you really need for a wiring harness is already in the crew. The 1st gen 12 valve is a "stupid" engine that just needs power for the starter (already there), alternator wiring (already there) and power to the shutoff solenoid (use the gasser coil wire). Everything else is non-essential.
6bt
youll be looking for a motor/trans/transfercase, all non modified bolt in except for the tcase crossmember? youll probably find another wrecked donor with nicer interior upgrade parts, if someones looking to sell just the motor, the donor is usually still connected, good luck, and nice crew project!
Thanks
The guy's got a 1993 cummins 213,000 kms (133,000 miles), pooched and gutted Getrag case with the Transfercase still bolted up. Complete running engine that he was swapping into a ford. He sold the intercooler, he's not sure if he's got another one to give me. Has a 93 Radiator, starter, alternator, wiring harness etc
He's got a set of injectors that he built with 8.3L cummins nozzles that are in the engine now, and he has started the engine with them but probably not driven it, and a set of original 93 injectors too. Says it runs good with the mod nozzles.
He's a heavy duty mechanic and likes to tinker.
What would something like that be worth
your 205 t-case will probably accomodate the cross member with the 2 door cab, or 4 door cab, on the older gassers, im not sure about the locate frame mounts, your engine mounts will be a direct bolt up, the frame at the t-case at worst, will be redrilled for the new location, longer motor, they didnt change much, going back to the '70's. you might want to consider a new venture 4500 to replace the gutrag worthy upgrade, especially mated to the 205. youll see 5.9 motors for 1000. not usually with trans and tcase, sometimes the whole rig for the same. dont be afraid of a 300k motor, still got lots of life if not overheated. on a side note, i paid 3500 for my wreck, in '03, there was a lot of purchasers to compete with.
Like Sooty said, somewhere in the $1000 range seems to be the going rate for a complete engine. Kinda hard to say with the T.case etc. $1250 - $1500?
Hey guys, this truck has dual fuel tanks, obviously the stock gas tanks for 1980 pump off the engine, can I still use these tanks for the Diesel conversion?
Is there a in tank pump that has to go in each tank or ????
Thanks again
P.S. The guy wants $1000 for everything so I think its a good deal, most adds up here in Canada guys are wanting anywhere from $3500- $4500 depending on year and milege for just the motor. I told him I'll take the motor so now I just gotta track down a Tranny. Probably just stick with a Getrag cause I don't think I'll push my motor past 300 hp. I was happy with the power out of my 2003 so I don't see why a 300 hp 1st gen will be any less satisfying
Thanks again
you don't need an in tank fuel pump...you'll have a lift pump (fuel pump) on the drivers side, lower rear of the block. Not sure if you can use the gasser tanks...can't see why not?
$1000 cdn for everything is a good deal!! I'd stick with the Getrag too...lots of aftermarket support for those trannies now.
Thanks again
Thanks again
