1st Gen All Products Sell all of your 1st gen products here. This includes trucks, parts, accessories etc.
Mark this thread as Unsold
Engine & Drivetrain Misc 1st Gen parts
Old 05-07-2015, 06:29 PM
Received 1,332 Likes on 862 Posts
Misc 1st Gen parts
TPS sensor and bracket off 93 auto truck...worked perfectly before removal...$125 Firm
A518 column shift linkage...$30
Non-IC upper and lower rad hoses...$25 for the pair
Non IC air box to turbo tube...$25
93 1st Gen cummins water to Hyd transmission fluid cooler....with brackets and clean cut lines...$125
1st Gen 4wd custom steering shaft. Uses a toyota U-joint. All redone with new parts...$100
1995 2wd NV4500 tail housing, with hole for speedo cable....$100
A518 tranny to 4wd cross member adapter...$25
1993 fuel tank strap, only one...$20
2wd NV4500 2 piece drive shaft...New u-joints and carrier bearing. Cut and balanced, for a 1984 D350 2wd crewab....$125
1989 1st Gen Cummins AC compressor and engine brackets...$125
1989 1st Gen Cummins AC lines, great shape....$125
D350 Good used, front rotors with Hubs...$125 for the pair.
93 D350 A518 tranny cross member and tranny mount...$125
1st Gen cummins D250/D350 2wd front spindles, splash shields and caliper brackets...$100 for the pair.
1st Gen cummins lower steering knuckles/arms...$100 for the pair
1st Gen Cummins 2wd upper control arms....$100 for the pair (New'er Moog ball joints, and bushings)
1st Gen cummins 2wd lower control arms....$100 for the pair. (Need new bushings and BJ's)
Have pics of all parts for sale. Shipping is on top of the prices you see. PM for more info.
thrashingcows is offline
Old 06-12-2015, 09:36 PM
Couple new Items to add....
90-93 Electronic gauges, Volt, Temp, Fuel, Oil pressure. All confirmed working. $20ea or $50 for the set.
81-89 gauges, Amp, fuel, oil pressure etc. $5 each
89/90 Auto steering column. Has keys. No turn signal lever or intermittent wiper wiring. Non tilt. $125
93 Cummins 4wd front leaf springs. $150
BTW all prices on parts are negotiable.
Old 06-12-2015, 09:38 PM
89 A/C lines are sold.
Old 08-01-2015, 11:55 PM
upper control arms, and steering shaft are sold.
Old 09-20-2015, 03:27 PM
OK new prices....
A518 column shift linkage...$25
Non-IC upper and lower rad hoses, used...$20 for the pair
93 1st Gen cummins water to Hyd transmission fluid cooler....with brackets and 8" of lines...$100
1995 2wd NV4500 tail housing, with hole for speedo cable....$75
1993 fuel tank strap, only one...$15
2wd NV4500 2 piece drive shaft...New u-joints and carrier bearing. Cut and balanced, for a 1984 D350 2wd crewab....$100
1989 1st Gen Cummins AC compressor and engine brackets...$75
D350 Good used, front rotors with Hubs...$50 for the pair.
93 D350 A518 tranny cross member and tranny mount...$75
1st Gen cummins D250/D350 2wd front spindles, splash shields and caliper brackets...$50 for the pair.
1st Gen cummins lower steering knuckles/arms...$50 for the pair
1st Gen cummins 2wd lower control arms....$50 for the pair. (Need new bushings and BJ's)
89/90 Auto steering column. Has keys. No turn signal lever or intermittent wiper wiring. Non tilt. $100
93 Cummins 4wd front leaf springs. $125
89 Cummins fuel tank. Complete with sending unit. $100
Old 09-29-2015, 08:15 AM
bigragu's Avatar
Hey TC, you still have the tps sensor and bracket? I'm interested. PM me will you- thnx
bigragu is offline
Old 10-16-2015, 02:47 PM
twichit's Avatar
The drive shaft do you still have it?
twichit is offline
Old 10-18-2015, 01:05 AM
Yes I do. But shipping would probably be co$tly!
Old 10-21-2015, 10:41 PM
RamW350 dually's Avatar
thrashingcows, would you happen to have a PCM? I need one for my 93 W350 with an automatic trans.
RamW350 dually is offline
Old 10-24-2015, 11:43 PM
Sorry I do not.
Old 10-24-2015, 11:45 PM
Update....
TPS and bracket - SOLD
D350 2wd Ball joint/steering Knuckles - SOLD
Old 10-25-2015, 10:33 PM
David Cook's Avatar
Im looking for the manuel 5 speed w/granny gear for my 1990 w250, wich has over 600,000 on original unrebuilt block,folks. Can anyone help
David Cook is offline
Old 10-28-2015, 07:21 PM
MrFusion's Avatar
I have a PCM out of a 92 W250 AT truck. I live near Harrisburg PA. PM me if you are interested.
MrFusion is offline
Old 11-03-2015, 07:16 AM
DOZENVALVE's Avatar
now that I see this ad, ive definitely come across your craigslist post several times
DOZENVALVE is offline
Old 11-25-2015, 04:37 PM
Quick Reply: Engine & Drivetrain Misc 1st Gen parts
