rear axle identification
Old 10-31-2016, 01:38 PM
deerslayer1979's Avatar
Bought an axle for my dad's 96' 2500. Was told it is a D80 I need to verify that. Per seller it is from a 90's Ford truck, but he didn't really know.
Thank you!
DS79
Old 11-01-2016, 11:18 AM
Required_Field's Avatar
That does not look like a Dana 80 to me -- the Danas have 10 cover bolts, this one has 12. 12 is typical of Ford.
Take a look at this differential ID page: Differential Identification | West Coast Differentials
Old 11-02-2016, 08:23 AM
patdaly's Avatar
Didn't count the bolts, but you are right, Sterling ( Ford ) 10.5" perhaps?
Old 11-02-2016, 09:42 AM
Received 2,378 Likes on 1,572 Posts
I don't every touch Ford stuff, but that is not a Dana 80.
Wrong center section with the wrong sensor location.
Old 11-02-2016, 02:38 PM
u2slow's Avatar
That's the big Ford full-floater without any doubt.
drum = 10.25" and 8x6.5" pattern
disc = 10.5" and 8x170mm pattern
Old 12-07-2016, 01:45 PM
Hey thanks guys, just saw you posted on this and I never responded. I now know it isn't what I was told it was. Guy doesn't want to crap about it and is convinced I am wrong. Not sure what I will be doing going forward, but finding a way to stuff a Ford 10.25 up his rectum is defiantly part of the process.
DS79
Old 12-07-2016, 10:57 PM
Mike L's Avatar
DS79
Ya know, video highlights of this return of the said Ford pumpkin could be highly entertaining. Whaddya think?
Good Luck to you.
Mike
Old 12-09-2016, 05:15 PM
richard's Avatar
If you look close, the seal on the outside of the pinion will have the ford oval on it.... As will the ring gear sensor and or plug for it. Take some pictures of it and show him.. That is definitely Ford, I work on a lot of them here.
Old 12-10-2016, 02:30 PM
u2slow's Avatar
Its a decent strong diff - on par with a 35-spline Dana 70. But typically cost half what a Dana 80 does.
Pro's:
- most likely the right track width. (64-65" for a 97-older SRW)
- slide off drums
- 9/16" wheel studs
- Brake hardware and cables are basically the same as 1stgen Dodge
Cons:
- 1350 yoke (usually)
- crush sleeve (but can be eliminated)
If I wasn't into it for much $$$, I would move the perches and run it.
Jasonbailey
11-18-2012 05:59 PM
Lunds Ram
11-11-2011 02:07 PM
Willie B
11-14-2006 09:03 PM
MX429
08-20-2006 06:41 PM
93' Shorty
07-20-2006 04:37 PM
Quick Reply: rear axle identification
