high egts how to lower them
Old 04-24-2012, 09:37 PM
rustydeeretech's Avatar
my 96 auto has a 100 plate in it and the egts are getting really hot pulling the dozer what do u recommend i do to lower them i can peg my gauge out at 1600 all day long i know the dozer is over weight for the truck but i would like to drive it not haveing to keep an eye on the egts all that time i was thinking turbo? if so what would be the best thanks
Old 04-25-2012, 06:49 AM
j-fox's Avatar
More air!
Or , less fuel.
How much boost are you seeing?
Air filter clean?
You can run more boost with a HX35 without hurting it.
Old 04-25-2012, 01:31 PM
Pickin on the wrong admin...
Diesel Dave2's Avatar
As J mentioned...You could also add water/meth system..
Old 04-25-2012, 04:47 PM
Lil Dog's Avatar
Without boost numbers, sorta hard to help, but air is the first part to get. That and some added timing would bring them down a tad at peak HP..
Old 04-25-2012, 09:03 PM
95ram's Avatar
IMO you need a different plate. A 100 plate isn't ment for hauling that kind of load. Get a 10 plate and dial the fuel back.
Old 04-26-2012, 03:26 PM
9812vram's Avatar
x2. I can haul all day long with my 100 plate - but I gotta watch the skinny pedal!
Reduce fuel or increase air. That's about all you can do.
Old 04-27-2012, 10:48 AM
infidel's Avatar
I second getting a #10.
I got tired of towing with a 100 in less than ten minutes.
I rather watch the road than the pyro.
It reminded me of a beater Chevy pickup I had as a teenager.
Previous owner put a branch though the radiator and crimped off about two thirds of the radiator tubes to keep it from leaking.
Had to constantly use the accelerator to control the coolant temp.
Old 04-28-2012, 07:21 AM
Don T's Avatar
Pulling my 10,500 fiver I never see over 1000 on the pyro and 38 lb boost. I like the fact that with the 10 plate I don`t have to watch the pyro.Just installed posilock and wish I would have done that a long time ago. Sweet that tranny temps don`t clime so much getting the fiver parked.
Old 04-28-2012, 07:34 AM
John_P's Avatar
rustydeeretech:
I agree with the advice the other members are giving you on changing your fuel curve torque plate.
I am also a big believer in the water injection systems for our trucks and have had water injection on my 1996 Dodge CTD 12 for over seven (7) years now with excellent success. Water injection will absolutley drop your EGT's under all conditions.
If you are interested, here is a link to a thread a bunch of us here contributed to on water injection. There is ALOT of info in the thread so get ready for some long reading:
https://www.dieseltruckresource.com/...n-t248415.html
Hope this helps you Sir!
lgp9999
09-08-2007 11:19 PM
inline6359
14
01-04-2006 09:23 PM
duallydave
05-29-2005 09:35 PM
BCarmicle
09-22-2004 12:10 PM
Boojie_00786
08-15-2004 11:26 AM
Quick Reply: high egts how to lower them
