fuel leak on left side of block below LP
Old 04-26-2012, 03:51 PM
TxDiesel007's Avatar
just a stupid question...
But i have to ask.... Is it possible that the lift pump gasket has developed a leak? or is my fuel heater the culprit... i have diesel fuel stains on that location of the block..
Truck is gettin a bit stubborn to start after it sits for more than a day or two, or more than 12-15 hours.. Starts up after two or three cranks, with some throttle, idles rough for a few seconds, and evens out with some throttle, and will start off easily the rest of the day....
I have checked return lines, OFV is good, all lines are tight.. i know its gettin air somewhere... which is why i ask the above question.. thanks guys!
Old 04-26-2012, 04:53 PM
patdaly's Avatar
Quite well could be the fuel heater. Get rid of it, you won't ever need it down there.
Old 04-26-2012, 08:18 PM
thanks pat!
Old 04-27-2012, 10:40 AM
infidel's Avatar
Leaking return hose can appear to be coming from most anywhere below it.
drewsta
04-13-2015 09:26 PM
Bushmaster
01-04-2011 08:05 PM
sallyman1
03-26-2009 10:28 PM
ChicagoSnow
09-03-2007 01:43 AM
DennisT
05-15-2007 01:22 AM
Quick Reply: fuel leak on left side of block below LP
