fuel leak
fuel leak
I have a 96 Cummings-96.000 mi. About 6 months ago, while driving- my fuel filter came loose, and dumped 30 gallons of fuel. The dealer replaced the filter, telling me the problem was the after-market filter came loose due to the engine vibration Prime-loc remote fuel filter system,
I now have fuel leaking (just a little) at the bottom of the filter. There appears to be some kind of plastic plug, not sure because its on the bottom of the filter. Is this going to start an engine fire ?
I plan to take it to my mechanic monday, but is it safe to drive ?
What you have leaking is your water in fuel sensor, might just be loose, or it might be cracked, either way not a big deal, nor should you burn the thing down by using it sparingly.
Don't let the mechanic bamboozle you either, here is the part you need, shouldn't take more than 3 minutes to change it either.......
Fleetguard 3831852S Water In Fuel Sensor at DieselManor
( Lots of other places to buy from, this was just the first one I found )
Fuel filter
thank you, I will find the part, and get it installed...very helpful info !
ps...I agree, and was questioning the explanation of the dealer, re the filter just coming loose..cant trust most of those repair places.
ZPOD
18
09-23-2010 10:37 AM
superdiesel9
10-25-2009 07:56 PM
donhov
26
01-06-2006 07:29 PM
Lightman
16
01-21-2004 10:46 PM
