FUel issue?? starts hard missies white smoke then runs fine
Old 07-25-2016, 09:03 PM
case310350's Avatar
Have an 97 12v and recently sometimes it starts hard, runs very rough, lots of smoke, gray, after 30 seconds starts to run good. Once in a great while after running it will start to miss, I get rpms up for 10 seconds and the its ok. Plan to change fuel filter. whats the best way to test the 2 low psi fuel pumps?
Looks like the problem will slowly get worse so looking for advice on narrowing the problem down.
Old 07-26-2016, 08:27 AM
patdaly's Avatar
Bet you have cracked hose or rusted line............
Easiest is to just get a tapped banjo bolt from a place like Genos and check it at the inlet of the Injection pump.
You should only have 1 low pressure transfer pump though.
Old 07-26-2016, 02:59 PM
dodgethis91cmns's Avatar
You have 2 low psi pumps?
Old 08-02-2016, 09:11 PM
case310350's Avatar
Is there a tank pump?
Old 08-03-2016, 09:37 AM
patdaly's Avatar
Nope............. Only the mechanical pump on the side of the block.
13ALPHA
24
05-04-2012 01:15 PM
jdddually
06-16-2011 09:18 PM
97catintenn
01-07-2010 11:33 PM
Luckyrogue
01-16-2008 11:54 AM
Quick Reply: FUel issue?? starts hard missies white smoke then runs fine
