Connecting Rod Torque Specs?
Old 05-18-2007, 10:22 PM
satburn's Avatar
Found this someplace else, can someone confirm this is correct for my truck?
Dodge Truck
Revised main and rod bearing torque procedures. If you work on 1986-2002 Dodge trucks, be advised that there are new crankshaft bearing torque specs and tightening sequences for Cummins 3.9L and 5.9L B and ISB engines. Cummins has determined that the torque-plus-rotate method of tightening capscrews applies a more uniform clamping load than the previous method, so this information applies to all B Series Cummins/Chrysler diesel engines.
For the main bearings, first make sure all bolt holes are clean and that all bearings have the correct and adequate lube. Then install all bearing halves and bearing caps with the numbers toward the oil cooler side of the engine. Use clean 15W-40 oil to lightly lubricate the bolt threads and underside of the main bearing bolt heads. Install the bolts using the proper sequence (see illustration). First tighten the bolts to 37 ft-lb, then spin the crankshaft a him or so to ensure proper rotation. Next, using the same sequence, tighten to 45 ft-lb. Lastly, tighten to 66 ftlb. Now, in sequence, rotate the bolts an additional 90 deg. After tightening, use a feeler gauge to measure the crank endplay between the No. 6 main bearing thrust surface and the shaft. The reading should spec out to .004 to .017 inch.
For the rods, use clean 15W-40 oil to lubricate the rod cap bolt threads and underside of the connecting rod bolt head. Alternately tighten the bolts to 22 ft-lb, then to 44 ft-lb. Next, alternately turn the bolts an additional 60 deg. Finally measure the rod side clearance, looking for .004 to .013 inch. Note: Be sure to measure the rod clearance, not the rod bearing cap clearance!
Old 05-21-2007, 05:09 PM
patdaly's Avatar
Boy, I don't know, Recon manual calls for oiled threads 26 Lb.Ft, then 52 Lb.Ft., final at 74 Lb.Ft. I would guess that an additional 60 degrees past 44Lb.Ft would be close, but just be very, very aware of any sponginess feeling thru the wrench.
Where did you find this info? The side clearances are almost the same as the recon manual, they list .004/.012 at the Rod half, not the cap.
Old 05-23-2007, 08:08 AM
satburn's Avatar
Here's where I found it.
http://findarticles.com/p/articles/m...11/ai_n9150210
I called around and it seems to be accurate. It seems like a little more than 74, but my clearances were in spec, so I went with it.
GOTMEAT
05-24-2004 02:37 AM
BigBlue
05-19-2004 09:52 AM
Synchiropus
13
03-22-2003 11:03 AM
latitud_rt
11-12-2002 07:36 PM
Quick Reply: Connecting Rod Torque Specs?
