boost elbow loose on 96 2nd gen p pump
Old 09-29-2016, 09:12 AM
sanddragon2004's Avatar
Guys so working on truck last night. Doing my research on pump tuning, and just going over things on the truck. I noticed this is loose like I can wiggle it side to side a fair bit. I assume this is getting air into it.
Trying to figure out effects this will have on the truck. Seems like it would be a boost leak and would affect boost pressure on the truck? I am going to pull it off this weekend and see if i cant fix it or what needs to be fixed. thought id ask the experts though hoping this didnt harm the truck in any way. It does have trouble reaching top speed on freeway and is very sluggish in top end.
Old 09-29-2016, 03:41 PM
gorms's Avatar
Manifold pressure feeds into the straight part of the "T", feeding the wastegate and AFC. Boost elbow adjusts signal to wastegate to delay it's opening. AFC limits fueling based on boost, less pressure = less fuel. So if the AFC is bleeding pressure off it won't allow full fueling.
Leaky Gasket
08-14-2008 07:17 AM
Munchies
02-04-2007 02:31 PM
Captain
12-17-2006 08:00 PM
dodgediesel
14
12-14-2006 09:54 AM
Quick Reply: boost elbow loose on 96 2nd gen p pump
