'96 12 valve auto trans holds 2nd to 3rd shift
I just recently bought a '96 12 valve dually with a remanufactured auto trans and it holds the 2nd to 3rd gear shift unless I let off to a lower rpm and then it catches and seems to shift sort of quick from 3rd to 4th. What could be causing this?
First check the throttle valve cable adjustment. After that I'd replace the govenor solenoid and the transducer together. If this doesn't fix it then it's an internal problem.
Thanks AJ!
Louie, take AJ's advice to the bank, he is a long time Chrysler trans guy.........
BTW, also check for codes, with a recently remanned trans it is possibly an unresolved wiring issue as well.
Thanks for the help guys. Where on the trans is the governer solenoid and transducer? and what kind of adjustment should the throttle valve cable have?
Sixpack73
32
03-06-2009 05:05 PM
Don M
27
10-17-2004 06:42 PM
