47RH parts help
47RH parts help
My transmission build is being held up by 1 small part. There is a retaining washer that holds the valve in place in the governor. It is approx 1.130 OD x .667 ID x .020 thick made out of hardened steel. Mine is broke in 2 and the transmission re builder can't find a replacement. Anyone know where I can get one ASAP?
Yes, #13. I wouldn't be surprised if the previous overhaul shop put the wrong governor in it.
None of the parts show as being made anymore.
Did find this, looks like the diesel governor from a A518 is the same, so you might have better luck finding one from a first gen spare trans........
Check out this thread.
https://www.dieseltruckresource.com/...3/47rh-264004/
Turns out it is a V10 trans. I seriously want to hurt someone. The guy that's putting back together is going to replace all the necessary parts.
RAKFIRE
06-01-2008 07:04 PM
CTD_Neil
07-19-2005 08:13 PM
