#16 |
Mine cracked at about 45,000. Got the whole top replaced when I rearended someone this summer.
My crack was all the way from the windshield to the airbag. Seen a few more that way too. |
#17 |
My 98.5 with the tan interior and 111,000 miles is NOT cracked.
My 98 with the grey interior and 73,000 miles is cracked. Go figure, maybe the dark interior is the issue??
__________________
1998 QC 4X4 SB 3.54-Antispin 12 Valve. Timed to 16.90*. Dynoed 11/05 - 310/675 Dynoed again 02/07 - 436/957 retimed to 19.5*, and some other pump stuff!! 1/4 mile time of 12.88@104. 11/2007--480/1000. Trustee, NC DTR#18 "That's Mr. McMosley to you!!" |
#18 |
Mine is cracked. I think it is where the plastic is scored from the back so it breaks easier when the the passenger air bag is deployed. It's on that side and that's what i figured, anyway. I have seen others cracked the very same place. I hate it but.......
__________________
Money Pit :( 99 3500 dually 4X4 club cab long bed, white with black trim, 235000 miles, Rino full length step bars, bed mat and cap, Phenix Gold Amp and sub in a custom box with An Alpine head unit and MB Quarts coaxle speakers in the front and rear doors, K&N filter, Schaffer oil products, B&D digital fuel presure, pyro, and boost gages, B&D inline axilary lift pump with oil presure switch, rebuilt trany with shift kit and aftermarket tork converter, Superchips programed |
#19 |
Mine was cracked at 50K miles, no real "heat" here, at least not very much of the year. I vote for they are just crap, like most of the other interior parts on most American made cars.
#20 | |
Quote:
I paid about $180 for my Light Gray upper half... (not installed yet) if you have a red or dark Gary... its about $100 more... go figure... Mine hasn't started cracking at the air bag.. but chunks are falling out above the radio... I'm about to lose a 6in piece of the dash... Bryan
__________________
"SawZaw Specialist" :D 2001.5 3/4 4x4 Sport Silver w/light Gray interior.. EGT/Boost/Fuel Pressure on the pillar... Polished intake horn, Rear Diff cover.. WildCat Fuel lines.. DD-DUFM... DDIII's.. Clutch from clutch-shop On the shop floor... DSS and 03 Track Bar Retro Kit. (TractorNut-TDR) 07/23/05... 413HP+CCF [dummy] 900+ft/lbs Dynamic Motor Trends :) |
#21 |
Mine cracked so bad I'm waiting for it to fall into my lap one day.
I sent some pics w/ email. I had already called in on this cuz the dealer wouldn't even say hello.
__________________
99 2500 2wd nothin fancy just the only engine worth putting in a truck |
#22 |
the gf's cracked right behind the steerig wheel, well on top dead center. got about 180k on it. austin heat. did i mention it's getting a full goerend tranny!!! can't wait , cracked dash and all. !!!
#23 |
The dash on my 2001 is cracked in two places. Bought that truck used in TX. The one on my 1996, bought new in HI is fine. On the 01, I just put the dash cover from Geno's Garage over it. Not a big deal to me.
#24 |
Funny you should mention
After just taking ownership of my 99 2500 (thanks dad) my dad and i noticed the dash was cracked. i found this strange considering i used to have a 91 with 230k on it and the dash looks as good as new. im happy to see someone is addressing this and as soon as i can gather the info i will send you a pm with the requested info. thanks
__________________
BROTHER: 1991 W-350 (SRW) Non-Intercooled, Getrag 5 Speed, 4" Exhaust, ISSPRO Boost and Pyro on Pillar, Minor Pump Tweak, MINE: 1999 2500 QUAD CAB, NV5600,2 INCH LEVELING KIT, 16X8 HELO MAX, 305/70R16 NITTO TERRA GRAPPLER DAD: 2004.5 3500, QUAD CAB SB, EVERY OPTION BUT LARAMIE(DAD DIDNT WANT LEATHER) NV5600, Bone Stock but this baby moves MOM: 2006 BMW 330i Silver on Black, Sport Package, Premium Package, 6 spd. Loaded |
#25 |
mines cracked been cracked for a while just use some 3 min expoxy on it and she good for another 100,000 miles .We all know dc is not going to do any thing about it they need to fix the fueling problems no fuel no go no need for a dash just my .02 cents
__________________
2000 q cab 2 wd 3500 ctd auto 4.10 gears silencer ring mia glacer fuel system edge comp tapped DD3's AFE stage 2 Dave Goerand Tranny and Triple Disc Converter |
#26 |
Mines cracked as well, light grey dash. Cracked around 40k mileage, lifted it up to thread the FP gauge lines and big chunks shattered off of it from the slight torque lifting it up. Live in Vancouver, Wa , not known for it's Sunny days! Anyways, I probably won't submit the info, they aren't going to fix it, but they'll be happy to give the impression they "might" just to get people off the phone. My .02
__________________
'99 Dodge Laramie SLT, 24 Valve, 3/4 ton 2500 4x4 Diesel Maxflow System, 3 gauge Cluster Isspro Pyro,Boost,Fuel. Air bag suspension. |
#27 |
I have stopped or slowed some of the cracks by drilling a small hole at the end of the crack. I used about a 1/16th bit and drilled by hand. If you don't get the hole exactly at the end of the crack, it will continue.
__________________
SUPPORT OUR TROOPS ! 1999 Ram 2500, SLT Laramie, Quad Cab, LWB, 4X4, 5 Spd, Camper/Trailer Tow Pkg, LS/RE, Westin step bars, Ram molded splash guards (front and rear),diamond pattern bed caps and toolbox, Isspro EV boost, pyro and FP pillar mount. FASS II on 6/5/05. Rancho RS9000's on 8/23/05. RV275's on 12/11/05. AirRites on 3/5/06. MBRP 4" on 3/14/06. DSS on 4/8/06. Smarty on 10/12/06. New front rotors and axle seals: 8/08 Jammer 3's on 9/6/08, South Bend Con O on 1/30/09 304/718 on 4/1/06. |
#28 |
My dash trim cracked on the driver's side at about 30k...
__________________
Never be afraid to try something new. Remember: Amateurs...built the ark. Professionals...built the Titanic 2001 4X4 QuadCab 2500 CTD 5spd; Weld Racing Rims; Tough Country Full Front Replacement Bumper; 2" Leveling Kit; Power Edge Drag Comp w/ wire tapped; Fuel Press., EGT & Boost Guages -n- Pilar Pods; 5" Exhaust; Magnum Force Intake by aFe; custom fuel system; Mach 4's; B-1 (saving for a set of twins); SBC CON OFE clutch (SBC 3850# DD waiting for install); NOS(waiting for install) |
#29 |
Mine is craked in several places. Dealer told me a new one is $179 so I will be getting on soon.
__________________
2009, 2500 SRW-4x4,6.7L,Laramie,Auto, Mega Cab, |
#30 |
My 2000 is cracked, Just noticed it last week. 117,000 miles.
__________________
2000 QC 4x4 2500 pillar mounted autometer pro-comp gauges,boost,egt,trans temp,fuel pressure gauge under dash,tool box, midland c.b. radio,Transformer mount with 9000i warn winch. FASS 150/95 Fuel system |
| Thread Tools | |
| Display Modes | |
