Thread Tools | Search this Thread | Display Modes |
#1 | ||
For you Getraggers
__________________
91 d350 non intercooled getrag kansas City, MO |
#2 |
Cool, something to look into. I'm about ready for a lube swap in the ol gutbag...
__________________
90/97 F350 4x4 SRW Crew/long Fummins |
#3 |
I sem to remember that the reason for the lightweight oil in the Getrag is the needle bearings don't get lubed with 90 wt gear oil. Better be careful with this one.
Edwin
__________________
1989 D-350 Dually CTD, WH1C turbo Non-IC, boost controller set to 34#, 3200 RPM govenor spring YAY!, Autometer Z-series Tach, Boost and Pyro, 5spd Getrag 360, A/C, Power Steering, Brakes, Windows & Locks. Replaced all seals and o-rings in the VE when I did the govenor spring. Paint sucks but I'm currently stripping/sanding/priming for new paint. See my photo gallery. |
#4 |
Mine has held 800+ foot-lbs. for a year so far. I'm running Redline's MTL.
When I got my truck it had gear lube in it, the trans had to warm up for about half an hour on the highway before it would shift smoothly. My experience with thick oil and Getrags has not been good. They do run quiet with gear oil, though.
__________________
Faith '93 D350 - DPS 6x16's, HTT Stage IV/14wg, PowerStroke IC, Snow water/meth, Walbro 392, Con-FE, pump tampering by owner. 390 HP/800 TQ on #2 only, 413 HP/852 TQ w/ water/meth - needs more air! Dead KDP's = 72 |
#5 |
If you'll notice the shockproof lightweight is rated to 75/140 spec but has the flow characteristics of a sae 30wt oil. I.E. this should be just fine in a getrag. I run the heavyweight in my sentra, it carries a 75/250 rating w/flow characteristics of dino 75/90 gear oil. This is an excellent product. If you question the viability of its use, simply call the redline techinical department and ask them what is best for your application. And like wanna has said he's been running MTL for a while with no hiccups. What I was initially advised was, if the trans is stiff when cold simply drive gently until it warmed slightly, this was NOT an issue. The heavyweight shockproof outperformed the dino 75/90 in all aspects. I also noticed a large temperature decrease when towing, while using their standard MTL in my nissan pickup.
product general description here http://www.redlineoil.com/products_g...61&subcatID=20 techinical specs here http://www.redlineoil.com/whitePaper/11.pdf |
#6 |
Gasssser trasssssh. 5w30 engine oil is the correct lube for the getrag.
__________________
Bill Gilbert 85 D350 crew with 90 6BT intercooled Getrag 3.07's 93 D350 single cab Getrag 3.54's |
| Display Modes | |
