Thread Tools | Search this Thread | Display Modes |
#1 | ||
What are yall doin for pump lubrication?
__________________
1992 w350 ex cab - 40 horse injectors, ex housing, 3 piece manifold, 3200 spring, bully dog fuel pin, deep cool pan and shift kit. Old truck - 1991 W250, 98k miles, 727 auto, non-intercooled Old truck - 1997 2500 4x4 NV4500 , 144k miles Old truck -1999 2500 4x4 quad cab, 205k miles, Auto, intake and straight pipe. Old truck -1990 250 4x4, 5 speed, air box removed and some pump work. Old truck - 93 Dodge w350 4x4, single cab |
#2 |
100% pure biodiesel; best lubricant, best fuel.
I heard of others running pump #2 diesel dumping in a little 2-stroke oil for lubricity.
__________________
CADTR #24 member number 5.9!! '93 Dodge Club Cab CTD with auto. "I thoroughly disapprove of duels. If a man should challenge me, I would take him kindly and forgivingly by the hand and lead him to a quiet place and kill him." -Mark Twain "If pigs could vote, the man with the slop bucket would be elected swineherd every time, no matter how much slaughtering he did on the side." -- Orson Scott Card -Congrats, liberal America; you elected the kings of swineherds! |
#3 |
I'm running a 2nd gen piston lift pump through a bypass regulator and that's it. I have been accused of running WVO and B100 in my tank but that's just because it runs better. I run the High Pressure lift pump to ensure fuel to the VE at all times so I guess I'm getting lube and cooling...we'll see.
__________________
92' W250 3:55's, Pump bombed: timed to head (soon to be +1 tooth), 366 spring, 1/2" fuel lines, bypass regulated piston LP, New Era 6x18's, HX40 18cm ext. wastegated, BHAF, 60lb in/ex springs, full gauges, 4" PAC Brake, onboard air, Nathan P3 horns. Next up? Studs, head work, twins, 2stg W/M |
#4 |
You still cant get all the water out of bio i know of more than a few that have had pumps fail do to watered down bio. Imo 2 stroke and cheap atf are very good.
__________________
93' D-250 K&N, 4'' DE exhaust,POD'S,fuel to collar, timming to head, BD manifold Gillette stage iv.. ksb hot wired. fuel pres, boost,Pyro ,tach,trans. 518 DTT converter, BD flex plate and kelderman bags.. labonte W/M kit. 93' D-350 4in exh pods k$n boost and pyro fuel collar deep trans pan goose neck. sold! My first one 90' w-250 727 pods k$n 4in exh 12cm full fuel goose neck hitch no gauges oops burned a piston! sold! |
#5 |
Pod Boy (on hiatus)
Check out this link, they did a lubricity test on all these additives, including bio, waste motor oil, all the popular diesel lubricity conditioners and 2 -stroke oil.
http://www.dieselplace.com/forum/sho...d.php?t=177728
__________________
93 Dodge D250 3.54, 4 stans downpipe to custom narrowed 6 inch mitres, custom 12mm VE by Giles, tach ,boost, pyro, fuel pressure, 68lpm ddp sticks, Garret stage 3 ball bearing turbo, airdog 150 with hellman sump, G56 with Gear Vendor, 3250 SBC clutch, helix 2 camshaft, fluid dampr, Amsoil filter, dual redtops, new paint. Uncorrected #'s 445 hp 925 tq 2000 Golf TDI 90 hp of pure ve powered fury that get 50 mpg!- smashed by red light runner |
#6 |
I've seen that one before. I wish they'd tested some of those at different concentrations. For example, they tested waste oil (Rotella T 15w-40) at a concentration of 200:1. Given the 30 gallon tank in the 1st Gens, that's about a half quart of used oil. Cummins used to approve the use of up to a 5% concentration of used oil, which is a heck of a lot more than 200:1 -- one and a half gallons!
I used to use a little less than a gallon per tank in my '92 to offset the poor lubricity of our winter blend fuel up here in Anchorage. The guy I sold it to in 2003 is my former boss and I'm still in contact with him. The truck is still purring like a kitten, and he has continued my practice. Personally I think good quality biodiesel would be the best thing, even just as an additive, but I can't buy it up here and I'm not comfortable making it. For me the next best thing is used oil. Mike |
#7 |
Pod Boy (on hiatus)
I too was curious as to why they used such a small concentration of wmo. I have a good bio station less than 5 miles from the house, I am going to be using the 50:1 mix of bio and see what happens.
#8 |
50:1 mix of bio (even if it's B100) is kind of a waste of time...IMHO of course. I've got 5 gallons of WVO on top of a tank full of B100 and I just drove 95 miles to work his am and have one so for quite some time. You won't notice anything with that amount except maybe the wonderful aroma...mmmm
#9 | ||
Quote:
Quote:
Also I have heard bad things about mixing WVO with bio in the tank, especially if there is any extra methanol left in the bio.
__________________
'92 D250, getrag, 3.50, 18cm....out of service '93 D350, DRW, A518 auto, 3.50, ext cab, BHAF, pump mods, 4" straight pipe '93 W350, DRW, A518 auto, 4.10, ext cab, stock....plow truck |
#10 |
B100
Be running B100 for years.If produced properly it will not hold water nor have traces of methanol. Brew my own to keep a high quality control.The bad rap on biodiesel is from bad producers.There is ways of doing it right.
__________________
Work in progress."89.5,getraged,D350,500,000+,stacks mounted horizontally,BHAF,yet to come-S300g,Denny Pin,gov. spring and pump tweaking |
#11 |
Alright well say im not a biodiesel guy yet and I just run to the truck stop to fill up...........whats the best thing to throw in too a full tank of fuel?
#12 |
I use 2 stroke oil.
__________________
Faith '93 D350 - DPS 6x16's, HTT Stage IV/14wg, PowerStroke IC, Snow water/meth, Walbro 392, Con-FE, pump tampering by owner. 390 HP/800 TQ on #2 only, 413 HP/852 TQ w/ water/meth - needs more air! Dead KDP's = 72 |
#13 |
Use 2 stroke 1 oz. per gallon
__________________
03 Quad Cab 6sp 4X4 Dually all Stock |
#14 |
Whats a good ratio to a full tank?
#15 |
I usally throw in about a half of quart of super teck from wally world. sometimes a full quart if I'm feeling generous!! But I really only put in about 15-18 gallons.. Don't trust my fuel guage, and it is easier on the wallet.. "so it may seem"
__________________
06 3500 Mega 3.5" TC Lift 18x10 pro Comps Mt's fender flares S&B w/scoop 5" Aero turbine 3 pillar cluster mag hytec diff 92 W250 Cummins 4" custom lift rear drop shackles 2.5 sky fronts 2" custom frt drop hangers Rear discs dual steer stab 2nd gen intc 35" MT's x 18" pro comp Whls 4.10 1/8 bump 366 spring 47rh Denny II Custom BHAF Custom Duals Guages More to Come 92 W350 Cummins Dump truck 1981 Dodge pwr wag 13" of lift lots of mods! Megacab Club Member #317 |
| Display Modes | |
