#1 |
What is wrong with my driving light wiring?
I have had this problem on both of my trucks, when running my driving lights for some reason the relay sticks on and either burns up my relay or this last time melted my fuse..... Just tonight the lights stuck on, I shut off my headlights and the driving lights stayed on. I just pulled the very warm fuse. What gives? Is it a bad ground? To much power drawing through the relay? Ask me questions and I will try to answer.
Thanks.
__________________
John Fort St John B.C. Canada 1998 12v, 4X4, QC, DTT 91% auto, 3.54 gears, TST #10, 370's, 3k GSK, PDR HX 40, 191's, 4 inch exhaust, Isspro boost/pyro/tranny gauges, 15.5 timing, Afe MC, Mag HT tranny pan. 04.5 4x4 3500 SRW LB 6-speed. Smarty Jr. & Hot Juice with Attitude. Carli starter kit, Kore control arms. |
#2 |
how many watts are the lights? sounds like your drawing too much amperage through your relay/switch.
#3 |
I agree. Too much current for the circuit to handle the way it was designed.
__________________
1996 Ram 2500 Club Cab, 4x4, 5 speed, KDP tabbed, Prodigy, Silverstars with relay kit, BD 4" cat back, Autometer gauges. I've donated. |
#4 |
Use a minimum 30 amp continuous duty relay for driving lights.
These will normally handle anything you want to run. If in doubt, get a more heavy duty relay with bigger contacts. I know that running lightforce, KC 150 watt, and the basic aircraft landing lights, a normal cube style bosch relay works fine.
__________________
01 2500 Q/C 4x4, factory order HO w/5spd, 4 wheel discs, Pacbrake, 285 Cooper STT's on 058 Eagle Alloys. Ultra 5th wheel hitch. Glacier Diesel GFS-392 LP 01 F550 XLT 4x4, Jokestroke, 6 speed, heila knuckleboom, boxes and deck, low mount 5th wheel. No mods, no power, no fuel economy, kinda like a ford.... HAHA Never judge someone until you've walked a mile in their shoes. Then, when you do judge them, you're a mile away... and you have their shoes |
#5 |
I am running Lightforce lights.... 10 inch. Not sure about the watts of lightbulbs. But there is a 15 amp fuse. So I need a 30 amp relay and 30 amp fuse... Wonder if the wiring is heavy enough? I just put in my lightforce lights with a Jetco light wiring kit.......
#6 |
10" LIGHTFORCE LIGHTS? wowsers....Must be like staring into the sun.
__________________
#7 |
nah, the 10" lightforce are pretty wimpy.
Get the 10" lightforce HID series... that is like looking into a welding arc. Knew a guy running 4 of them, two on each side of the hood on a pete 379. Following him at night was like driving along behind the sun. It was great. Meeting him... that was another story entirely, but he was really good about having them off in plenty of time. |
#8 | |
Quote:
__________________
Member #33 - DTR MegaCab Club Join Here Another Version-AD150 Canister Mod / MegaCab Install 2007 Khaki Dodge 3500 SLT MegaCab SRW 4x4 5.9L CTD 6-speed handshaker, SBC dual disc, smoked cablights, front & rear Timbrens, Pacbrake PRXB, Bilstein 5100's, DSS, lost kitty & demufflerized, Scotty V, aluminum front bumper, remote controlled aux. lighting, Commander, Smarty POD, AD150, 2" leveling kit, Espar, P3, 80% debadged, Amsoil everything, & some bling. |
#9 |
Another thought is, you could also have a pinched or rubbing wire somewhere, that is making intermittent contact.
#10 |
You need to find out the wattage, and use it to determine the maximum amperage, or measure the draw with an ammeter with the lights hooked directly to a power source. 14 gauge wire is good for maximum 15 amps, 12 gauge wire is good for maximum 20 amps, 10 gauge is good for maximum 30 amps. When I design a circuit, I will load the wire to no more than 80% of its maximum capability. Also, if the lights would demand over 18 amps together, I would consider wiring each one separately with its own relay, then use a single switch to control both relays together.
#11 |
I used the Lightforce harness and it only has a standard 30A relay in it.
What are you using as your signal/ground?
__________________
97 2500 4X4 LWB CC SLT Laramie 5spd LSD 3.55. Isspro EV's pyro/boost, #10 Plate, PEAK 3K GSK, AFC Spring, DDP III injectors, S300 Turbo, PEAK IC Boots, TAG III, South Bend 13-1.25" Con FE clutch, SCOTTY II-UNI, MBRP XP 4", KDP Tab, 16° Timing, SS DSS / 03TBK, Roda Deaco PAS. Espar D5WSC heater. B-Quiet sound deadening inside. Dyno 09-2009 401 RWHP / 1050 Ft-lbs '08 2500 4x4 MegaCab Laramie, 6.7, 68RFE, 3.73 LSD, S-67ME POD. Alberta Chapter #5 Prez... PM me for details... |
#12 |
Run a set of wires for each light 14 OR 12 guage. I usually use that 2 wire trailer wire, the stuff tha has that huge rubber insulating around the wire. I use the hella 30 amp relays. The relay has two 87 terminals each one is rated for 15 amps, so use one 87 terminal for each light. 30 amp fuse can be used.
__________________
2001 2500 5.9 with 290 000km. Mods- AFE stage 2 intake, mbrp 4 inch cool duals. Smarty, head studs, fass 95, Auto meter ultra lite 2, feul pressure, boost, pyro. hotrod pump, southbend con fe, phat shaft 62. |
#13 |
This is my new plan of attack. Using this relay in the picture. I am thinking it is a 60 amp relay. Going to use a 30 amp fuse in the new fuse holder. Now for wiring 101 for dummy's I am going to ask a simple question if this will work.
Big post on far left = fused power from battery. Small post on left = Ground Small post on right = signal from highbeam/switch Big post on right = power to Lightforce lights. How do I not have power to my relay when I accidentally leave my switch on for the lights and have my daytime running lights on? That gives out about 3-4 volts and can sometimes make a relay switch stick or have issues. Besides the obvious, turn off the in cab switch when not in use! ![]() |
#14 |
Signal is off the white/grey wire on the passenger side high beam that goes through my switch then to the relay. Ground is just to the fender where a bunch of other things are grounded from the battery.....
#15 |
I had the same issue with my DRL's and relay set up. I just unplugged my DRL module and jumpered the pins for the high beam indicator. I was thinking of using a 12V diode to block the low voltage coming from the DRL module.I just couldn't be bothered to play with it.
__________________
'96 CC LB slt,auto,3:54's,100hp Maxsticks,3k gsk, afc modded,16*,62/70/13 Turbo,4"exhaust,bhaf, DSS, triple lock TC, rebuilt auto & diff,MBRP 4",3 pod pillar egt, boost, oil pres,ride rites frt & back w/ onboard air, lubetech through out, 437K km's 333hp 760 ft/lbs |
| Thread Tools | |
| Display Modes | |
