Go Back   Dodge Diesel - Diesel Truck Resource Forums > Specialty Forums > Fuels / BioDiesel / Diesel Prices
Register Forgot Password?
Search
submit to reddit
Thread Tools Search this Thread Display Modes
Old 05-26-2008, 01:38 PM   #1
Gunz4all
WMO and the CRD
As we all know, diesel is getting really out of hand with no relief in sight. I am going to start doing my own biodiesel but would like to do a 50/50 mix of Bio and WMO. Has anyone out there burned WMO in their CRD, 04.5 or newer, and what effect did it have on the engine besides better lubricity in this land of ULSD? I will be doing a 2 Micron filtration of the WMO, so clogging the fuel filter should not be an issue. Coking, Catalyst problems? Thanks for any information you guys can share.
Gunz4all is offline   Reply With Quote
Old 05-27-2008, 03:03 PM   #2
sdaly
sdaly's Avatar
I've been running WMO (1-2 gallons per fillup) in my '05 CTD. No problems at all. Engine runs a little smoother and quieter.
__________________
Black 2005 Dodge Ram 2500 CTD SLT 4X4 LWB 6-spd manual G56 -- Mods: Ranch Hand Legend, Bilstein shocks, Ride-Ride Air Bags, Pace Jackrabbit tonneau
sdaly is offline   Reply With Quote
Old 05-27-2008, 06:56 PM   #3
Desert Dually
Desert Dually's Avatar
Quote:
sdaly, about how many miles have you run the WMO? I am very curious about this, and honestly have considered doing it, but am also concerned that it could damage the fuel system on the Common Rail trucks. Do you run the oil thru a centrifuge first? What about its effect on the catalytic convertor? Do you still run the stock fuel filtration system on the truck or have you added an aftermarket high-end one ? Sorry to bombard you with all these questions, but it seems like you have boldly gone where no man has ventured to go before (and admit it publicly in a forum ), and actually run WMO in a truck with a fuel system that costs 2500 dollars to repair, and not to mention injectors, sensors, etc. But heck man, if this can be done relatively easily, it sure sounds a heckuva lot cheaper and easier than brewing biodiesel!
Anything that can offset the insane fuel prices we are all being hit with, is a help
__________________
2007 Megacab SLT 4x4 Dually - 5.9 48RE, Line-X, Tekonsha P-3, powersteps, 2" leveling kit, Safari Off Road trackbar, fender flares, stock wheels shod with 315/70-17 Yokohama Geolander all-terrains, with 2" Performance Wheel billet DRW spacers, Firestone Ride-Rites
DTR Megacab Club member # 71
2003 Kawasaki KLX 400 SR
2000 Kawasaki ZX-12R
1985 Yamaha RZ-350
Desert Dually is offline   Reply With Quote
Old 05-28-2008, 05:41 AM   #4
tesla440
tesla440's Avatar
According to the manual you can run up to 5% of WMO from the engine straight into the tank. I've blend more than that with Kerosene + PS & filter to 5microns with a waterfilter polishing step before it goes into the tank of a stock fuel system.
I do plan on getting an AirDog when the funds become available.
__________________
2005 Black Sport QC 2500 auto 3.73 Swiss cheese Air box w/ Proguard 7 stock replacement filter, Airaid MIT, TAG, ATS ArcFlow, Quad Boost Fooler, Quad Commander w/ fuel pressure kit, Smarty S6 POD, 4" BMRP muffler with Aero in place of CAT, '06 metal intercooler (10mm [little more than 3/8"] thicker than original plastic), AD II 165, Roadmaster active suspension, Goodyear LT 275/70R18
tesla440 is offline   Reply With Quote
Old 05-28-2008, 09:53 AM   #5
ian515
Quote:
I thought cummins approved 20% recently?
__________________
'03 2500 aFe stage 2 intake, silverline 4" turboback exhaust. predator, fuel tank vent mod,
48re, flux 1's
ian515 is offline   Reply With Quote
Old 05-28-2008, 10:04 AM   #6
jkitterman
The 5% and 20% were referring to biodiesel blends not Waste Motor Oil.
jkitterman is offline   Reply With Quote
Old 05-28-2008, 11:02 AM   #7
ian515
ahh got it
Old 05-28-2008, 07:26 PM   #8
sdaly
sdaly's Avatar
No problem. To answer your questions, it's probably been about 2500 miles since I started pouring in WMO. No centrifuge. I just pour the WMO through a coffee filter (very slow), t-shirt material (faster), or Shop Towel (also faster), let it sit in the container for maybe a week or two, then it gets poured straight into the tank. I usually dont pour the last part of the bottle so to minimze picking up sediment off the bottom. My CTD's filter system is bone stock and it hasn't plugged a filter yet. My CTD is an '05 so I don't have an exhaust sweeper/catyllitic converter to worry about.
To mix it, I'll usually pour some in the tank, then add diesel on top of it, then pour in a little more oil, add more diesel, and so on, but it's probably not necessary. I usually also try to splash a little Power Service in the tank while I'm at it too.
I mentioned this to my neighbor the other day, who is an ASE mechanic with his own independent shop. He didn't see any problems with it either. He just shrugged and said that's a good way to get rid of old oil and save a few bucks.
Old 05-30-2008, 12:53 PM   #9
heykw
heykw's Avatar
What is the highiest % anyone has ran on WMO?
__________________
.Wake up America, end affirmative action! If not now when?
“A wise and frugal government, which shall leave men free to regulate their own pursuits of industry and improvement, and shall not take from the mouth of labor the bread it has earned – this is the sum of good government. “Thomas Jefferson
A government big enough to give you everything you want,
is strong enough to take everything you have.
-Thomas Jefferson
heykw is offline   Reply With Quote
Old 06-10-2008, 03:13 PM   #10
Desert Dually
ok, I'm trying it
I put 5 quarts of 1 micron filtered WMO in my tank a few days ago. So far, have driven about 75 miles, can not tell a difference at all, exhaust smells no different, drives the same, etc. Wonder how long the cat-con will last now?
Old 06-10-2008, 07:07 PM   #11
jriggs_18
jriggs_18's Avatar
Currently Im running about 60% with no ill effects, been doing it for a couple of months, Ive been as high as 90% but it gets really smokey.
__________________
99' QC Sport 4x4 Auto Red 115k mi. #53 Block
4' Turbo Back Exhaust
M/T Rims and 285 Courser CT's for now
K & N Air Filter
Juice w/ Attitude w/relayed VP tap
New VP at 90k
GDP Walbro 392 fuel system with 10 and 2 micron remote filtration from fleetguard
Goerend Triple Disk TC and VB w/A-pillar VDO gauges on line pres.,gov. pres and reverse pres.
Stage V Jammers
jriggs_18 is offline   Reply With Quote
submit to reddit
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.6
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
vB.Sponsors
Copyright 2011, DieselTruckResource.Com
Contacts Backup
