Go Back   Dodge Diesel - Diesel Truck Resource Forums > 3rd Generation Ram - Years 2003 and up > 3rd Generation Ram - Non Drivetrain
Register FAQ DTR Store Members List Mark Forums Read
Thread Tools Display Modes
Old 11-01-2009, 03:36 PM   #1
radshooter
radshooter's Avatar
Window switch quit working
The switch on my driver's door that controls the passenger front window quit working a few days ago. The window works from the passenger switch, so I am sure it is the switch in my door.
I popped the module out of the arm-rest, but couldn't find any loose wires. Is it worth taking the module itself apart? Can the individual switch be replaced or do I have to replace the entire module?
I tried contact cleaner spray, but that didn't do any good.
Thanks for any ideas.
__________________
03 Silver 3500 SLT 4WD CTD HO NV5600 3.73 DRW LWB Dipricol Boost and Pre-turbo EGT, AFE/Torque Tube, Jacob's Exhaust brake, Jordan, diamond plate bed rails, diamond plate mud flaps
radshooter is offline   Reply With Quote
Old 11-01-2009, 03:51 PM   #2
Raspy
Raspy's Avatar
I tried to fix mine recently. One I got apart and I broke the drivers side one trying to pull off the switch knob. They have points inside that get burned, but could be filed with a slim jewelers file if you get it apart without damage.
You can order a new one from Rockauto that is an aftermarket design and fits right in. Who knows if they are any better.
__________________
John
Prepare to stand by!
'04 2500 4WD std cab, HO, 48RE, TC, VB, Hytec pan, Dynatrac, '08 steering linkage, track bar, '08 H2s, Toyo 285/70 E, Smarty, Walbro, gauges, Brakesmart, exhaust "out the side", intake tube, billet filter lid, Kilby guard, KYB front, Rancho 9000s rear, Timbrens, PW flares, rear blocks missing, front 1" lift, wheel well liners, debadged, splatted bugs, hood pal.
Raspy is offline   Reply With Quote
Old 11-03-2009, 09:11 PM   #3
radshooter
radshooter's Avatar
Thanks Raspy.......I'll check it out.
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.6.7
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
vB.Sponsors
Copyright 2003, DieselTruckResource.Com
