Main Page Classifieds Tech Facts Member Photos Articles Links Forums Chat
Go Back   Dodge Diesel - Diesel Truck Resource Forums > 1st and 2nd Generation Ram - Years 1989-2002 > 24 Valve Engine and Drivetrain
Register FAQ DTR Store Members List Mark Forums Read
Thread Tools Display Modes
Old 11-03-2009, 02:04 PM
marine4life's Avatar
marine4life marine4life is offline
Wierd thermostat Issue
On the drive from Colorado to Nebraska the truck ran amazing in the cold. I got 4 miles from Omaha and suddenly my coolant temps sky rocket. Turns out the water pump took a dirt nap and an entire radiator worth of coolant baithed my engine bay. Got to my brothers and changed out the water pump(thank god they are so easy on these things), and refilled the antifreeze. I also changed the thermostat with the 190 degree replacement. Before my temps were a rock solid 188 degrees no matter what I did. Now with the new thermostat my temps cycle from 195 degrees to 208 degrees up and down. Is this too hot for this engine? Thanks for the help.
Bryan
__________________
2001 Dodge 2500 4X4 5 Speed
BHAF, Quadzilla Adrenaline,Smarty, Fass, Stage 3 Water/Methanol Injection, Mach 6+'s, HTT 62/12, SB DD, Oring's and Studs to come
491/999 TQ "Foreign Automotive" 080322
544/1220 TQ "Foreign Automoive" 080322(ON DRUGS!)
533/1087 TQ "Wayne's Dyno" 080330
"Uncommon valor was a common virtue."
Fleet Admiral Chester W. Nimitz speaking of the marines at Iwo Jima.
"The more Marines I have around, the better I like it."
General Clark, U.S. Army
Old 11-03-2009, 02:32 PM
klx650a2's Avatar
klx650a2 klx650a2 is offline
I would say your temps are fine. Did you use a genuine Cummins thermostat?
__________________
2007.5, 2500, QC, Laramie, 4X4, SB, 68RFE, 3.73, Inferno red, MaxBrake, Edge Insight w/pyro, Firestone Ride-Rite, EZ Change Drain plug, S&B drop in air filter, 250 watt oil pan heater, EGR unplugged.
2008 YZ450FX, matching 756's, Marcel Fournier ice tires, billet fuel screw, DiD narrow x-ring chain, Ironman sprockets, Scotts SS oil filter, Dr. D pipe coming, love the SSS suspension...
Old 11-03-2009, 03:40 PM
Smokin98.5's Avatar
Smokin98.5 Smokin98.5 is offline
I'd run a 180. Only because when towing My truck will come up 10deg. more then normal. I don't like anything over 205 degrees myself.
__________________
1998.5 Dodge 2500 quad\cab 4wd L-box, 5-speed.
Quadzilla Adrenaline w\pulse , 4" pipe, Jammer stage 5's, HI-TECH 71ser 64\12cm, LUK Gold clutch, BD Short shift, FASS 150, .
Old 11-03-2009, 10:56 PM
ironbutt's Avatar
ironbutt ironbutt is offline
Send a message via Yahoo to ironbutt
If you had gone to a certified Cummins shop, They would have asked for the motor # and given[sold] you the proper 180 degree that Cummins calls for. Only a Cummins part should go in there or you will be plagued with temperature swings instead of the rock steady 180 that the Cummins part will give you.
__________________
2002 2500sport quadcab auto 354 gears,gauges,mag hytec,tranny&rear diff,powerpuck,str8 pipe4",bilstien's
,B&Wturnover.60 gal aux tank/toolbox combo,BHAF,vulcan SS fuel fittings and lines.In tank pump at 80k,165,000mi & pulling.Downsized to a TT from 5th whl.toy hauler
Old 11-06-2009, 01:51 PM
SIXSLUG's Avatar
SIXSLUG SIXSLUG is offline
01's require a 190 and were delivered new with it. A 180 is fine, however.
Diesels like it hot and run well in that temp range.
208 isn't really that hot. I wouldn't sweat a 13 degree variation. You're fine.
Kurt
__________________
2001.5 2500 QC LB 4WD H.O. 6-SPD SLT Laramie Plus
Arctic White,3.54 gears, Camper/Tow, Stull stainless running boards, A.R.E. cab-hi canopy w/ SS Vanguard rack, Southbend clutch and hyd.,Power Service, BHAF/heatshield, MBRP 4" TBE, FP gauge, Femco E-Z drain plug,DSS, Thuren trac bar, 2" leveling kit, P/H tow mirrors, new intank LP @80K, 91K miles.
Next mod: Smarty, EGT gauge
Support Our Troops! NRA, MSBL, BYO
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.6.7
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
vB.Sponsors
Copyright 2003, DieselTruckResource.Com
