Main Page Classifieds Tech Facts Member Photos Articles Links Forums Chat
Go Back   Dodge Diesel - Diesel Truck Resource Forums > General > Big Rigs
Register FAQ DTR Store Members List Mark Forums Read
Thread Tools Display Modes
Old 08-18-2009, 10:04 PM
Stamey's Avatar
Stamey Stamey is offline
Why Super Singles?
Every now and then I see them on 18 wheelers, or would that be actually 10 wheelers if they are running super singles, but what is the advantage of super singles?
Durability, wear, price, strength, looks, ride?
Kinda wish I could fit a set under my truck.
Thanks,
Chris
__________________
Got TWINS? :D
Artificial Intelligence is no match for Natural Stupidity.
And by the way, I have an abnormal affection for my truck. My support group for this affliction is DTR Chapter #7 (like an alcoholic hangin' with his drinkin' buddies). [laugh]
1999 2500 CTTD, 4x4, QC, SWB, AT, loaded. What's my truck got? An obscene amount of torque, and an ATS tranny, repaired & upgraded with DTT parts. :rolleyes: PM me before you buy ATS.
Tim Barber (TimInVa) is THE MAN! THANKS Tim!
Now Overvalved AND Undervalved (got a 96 :D)
http://www.Stamey.Info/Truck
Are you a Diesel Head?
Old 08-18-2009, 10:16 PM
Sapps Sapps is offline
Advantage = Weight savings
Disadvantage = everything else
Mostly used by tankers, dumps, hoppers where more product hauled equals more $.
__________________
2007 3500 Laramie Quad Cab Dually - 5.9, 48RE, 4X4, 4:10's
GDP Intake Manifold, MPI Twins HTT 62/71/13-SS & 74MM S400, Smarty,TS MP8, DonM F1 Flux 1's, Goerend Full Billet I/I/O Trans w/ TripleDisk TC, ATS Billet FlexPlate, Silverline 5" Exhaust/No Cat/Aeroturbine /6" Tip, Spearco IC, GDP 392 Comp Fuel System, Coolingmist ST2 H2o, 19.5" Classic Alcoas
DTR Twins Club Member #28
Old 08-19-2009, 01:43 AM
Nick02Ram Nick02Ram is offline
Like Sapps said...if ya look in the product catalogs they claim they get better mileage, wear better, run cooler,less weight, blah blah blah. I personally haven't been that impressed. We sell, well sold, em to a fleet and after 6 months they pulled em all, virgin tires. They did get some money back from the manufacturer, and they came out to inspect some of em. They were cupping like crazy, which may have been an alignment issue, but they wore out way too quick, even if the truck was tracking wrong. However, as the cupping got so bad, they had to replace em at somethin like 600-700 a peice. We cap em with trailer tread and they are still running those, but phasing them out as well. The thing with that is, a dual wear uneven and ya replace one, 300 bucks, a S.S. wears out and ya replace it- 600 bucks. The other big problem I see is blowouts. When they do blow, they don't usually give much warning, and being as its the only tire on that position, your truck drops to the rim immediatly. This means getting stuck on the side of a busy road, which is damgerous for the driver, as well as me, who has to change it where it sits. If you run duals and have a blowout, you can nurse it to a rest stop, or at least an emergency pull-off. So basically my opinion is overrated.
__________________
02, 24v, 6 speed, Edge Juice w/ Attitude, BHAF, 5" exhaust to dual 7" turnout stacks, 35" Pro Comp Xtreme AT's, silencer ring removed, 1700 watt stereo, XM radio, CB, Eaton Fuller shift knob, Fuel Boss Mechanical Lift Pump
Old 08-19-2009, 01:08 PM
SpeedyWS6 SpeedyWS6 is offline
They say weight savings and fuel savings. The idea is that any time a set of duals is doing anything but going dead straight the tires are fighting one another. We all know the benefit of less rotational mass.
I know of a fleet of trucks that runs supers on truck and trailer and I have never seen them with bad wear. But I don't personally work on them or any other trucks with supers.
__________________
2007 5.9 CTD Q/C 6 speed: muffler delete, Willy's Whistler, drop shackles, BDTD, SB 3250DD
2002 Pontiac TA 6 speed: Viper shaft t56, Ford 9", cam, nitrous, full bolt ons. 10.02 @ 136 shifting them myself!
Real race cars have three pedals!
Old 08-19-2009, 02:00 PM
Lil Dog's Avatar
Lil Dog Lil Dog is offline
What would that large tire surface be like in bad weather, like snow, slush?
__________________
97 2500 4X4 LWB CC SLT Laramie 5spd LSD 3.55.
Isspro EV's pyro/boost, #10 Plate, PEAK 3K GSK, AFC Spring, DDP III injectors, S300 Turbo, PEAK IC Boots, TAG III, South Bend 13-1.25" Con FE clutch, SCOTTY II-UNI, MBRP XP 4", KDP Tab, 16° Timing, SS DSS / 03TBK, Roda Deaco PAS. Espar D5WSC heater. B-Quiet sound deadening inside.
Dyno 09-2009 401 RWHP / 1050 Ft-lbs
'08 2500 4x4 MegaCab Laramie, 6.7, 68RFE, 3.73 LSD, S-67 R15ME.
Alberta Chapter #5 Prez... PM me for details...
Old 08-19-2009, 03:28 PM
dj_souvlaki dj_souvlaki is offline
Quote:
my guess would be horrible. the wider the tire the more chance of hydroplaning.
__________________
2001 suburban
2002 Dodge Ram 2500 SLT Laramie 4X4
stock engine other than k & n filter
dodge mudlfaps
billet grill inserts
bug deflector
window visors
*SOLD*
1989 VW Golf N/A Diesel
52 hp of fury
*SOLD*
Old 08-19-2009, 05:26 PM
archer39's Avatar
archer39 archer39 is offline
Our neighboring fire department in our township just purchased a new Tanker and it has the super singles. Last winter after they just got it they slide it off the road while it was raining. They all claim it is very bad in poor weather.
__________________
93 W250, 47rh (Goerend torque converter & valvebody) boost, pyro,trans temp, and fuel pressure gauges, 366 gov. spring, fuel screw maxed, home cut fuel pin, potentiometer controlled OD, 5" miter cut stacks, gillett stage 2 (60mm wheel/housing), BHAF, coal train EDM 435 injectors, piston LP, pump advanced a tooth
Fall Brawl 08 304hp/525tq (slipping 518 trans)
Spring Fling 09 393hp/746tq (after 47rh swap and more timing)
Wanna join the PA Chapter??? Read how here
Old 08-19-2009, 06:28 PM
wannadiesel wannadiesel is offline
How can I best help you today?
Yup. Minimum tare weight is what it's all about.
__________________
Dave
wannadiesel@dieseltruckresource.com
'93 D350 - DPS 6x16's, HTT Stage IV/14wg, PowerStroke IC, Snow water/meth, Walbro 392, Con-FE, pump tampering by owner.
386 HP/774 TQ on #2 only, 408 HP/844 TQ w/ water/meth - needs more air!
"Butterscotch" - '82 Mercedes 300TD
KDP body count: 72
Old 08-19-2009, 06:35 PM
Stamey's Avatar
Interesting. Thanks for the info. I'm learning new stuff here.
Chris
__________________
Got TWINS? :D
Old 08-19-2009, 08:40 PM
1-5-3-6-2-4's Avatar
1-5-3-6-2-4 1-5-3-6-2-4 is offline
Around here I'm noticing more and more of the new build heavy iron oilfield equipment (wellhead service equipment) with tri axle super singles. I've only seen maybe 2 tractors with super single drives come through our shop in the last year. so they're not that popular around here on trucks anyways.
__________________
Luke
'97 Chevy V3500 CC DRW 6BT 22" Alcoas
'98.5 24v 2500 QC 5spd 4wd Demon hot-rod *sold*
'90 VW Jetta 1.6L oilbrnr 5spd coupe wolfsburg
'73 RS/Z-28 Survivor.
Old 08-19-2009, 09:33 PM
12valve@heart's Avatar
12valve@heart 12valve@heart is offline
I've seen super singles quite a bit on the front of cement mixer trucks.
My guess is that flotation is another advantage thus the use there and on oilfield equipment. Gotta stay on top of that mud.
__________________
Jay
'92 D250 Ext. Cab non-LE (manual windows & locks, rubber floor mat, steel headliner), CTD, MU0090 Ralley, Getrag rebuilt by Jay, 3.54, 18.5 cm, D-Celerator exh. brake, 3" pipe into 4" resonator dumping in front of rear tire, BHAF/Outerwears in Old Smokey Mount, head and tail lights on relays, 3” shoes & GM wheel cyls, Tach-Boost-Pyro-Oil Press-Volts-Water Temp-Air Press-Trans Temp-Fuel Press Gauges, Pump bump and KDP dead thnx to WannaDiesel, '93 Jayco 3500FS TT in tow, 287K and counting
Old 08-19-2009, 10:53 PM
the big wide tires on steers, aren't super singles. they're flotation steers like you think. super single replaces any duals. and they're different sizes than the float steers.
and either way dozers have been dragging iron in and out of drilling leases for 1/2 century it doesn't matter whats on them for rubber.
__________________
Luke
Old 08-19-2009, 11:01 PM
Riflemanusmc's Avatar
Riflemanusmc Riflemanusmc is offline
Registered user
They wear like crap. Inside tread on the tire's wears out fast. They didn't get the offset/inset correct. And it shows....Flex, no one thought that far ahead....
__________________
04 QCSB 2500. Smarty.Opies MITUSA.Opie's Bypass. Marine valve cover. ATS exhaust manifold. Boost.Pyro. RP gauges. 5 inch ex. Willy's intake 06 turbo w/boost elbow ARP studs. Springs
coming. SB DD and twins coming soon. SOLD New ride.91 with 68000 miles. Bought from the first owner.....Children, should be seen.Not heard...
Old 08-20-2009, 12:44 AM
I've had a few guys tell me they have a hard time pulling out of a dock in an inch of snow, even with their interlock in.
__________________
Old 08-20-2009, 10:24 PM
2006Mega's Avatar
2006Mega 2006Mega is offline
Quote:
back when i worked on semis we would send the new freightliners to the alignment shop to get the drives set where they should be. guess they were way off from the factory and were going through drives way to fast.
the supersinges steers also carry more weight, here im michigan you are allowed 18,000 on the steer axle with those wide floatation tires.
__________________
2006 Black Megacab, 4X4, Auto, 4" silverline turbo back. pac-brake exhaust brake. 9'2" boss v-plow.
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.6.7
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
vB.Sponsors
Copyright 2003, DieselTruckResource.Com
