Go Back   Dodge Diesel - Diesel Truck Resource Forums > 3rd Generation Ram - Years 2003 and up > 4500 / 5500 - Chassis Cab Trucks
Register FAQ DTR Store Members List Mark Forums Read
Thread Tools Display Modes
Old 10-19-2009, 06:57 AM   #1
Remudadoc
Why the lower HP/Torque in a CC
I have a brand new, 4500 with a custom hauler bed for pulling a large horse trailer. Why do the CC's have lower horsepower and torque than the 3/4 and one tons? That seems completely backwards to me.
Remudadoc is offline   Reply With Quote
Old 10-19-2009, 08:32 AM   #2
RAMRODD
I don't get that either. And to top it off when the new bodystyle comes out the chassis cab is rumored to have urea injectin where the 2500/3500 pickup versions dont. Why would the engine with the lower hp/tq rating need more emission equipment then the higher hp/tq version?
__________________
06 BLK quad cab DRW 3500
TST/Smarty
Stage 1 CP3
Southbend 3600 DD
22.5 wheels
Dynatrac free spin kit
ATS 3000/5000 twins
Firestone Airbags
Pacbrake
Transferflow fuel tank/tool box
1" lift in front from Top Gun Customs
Srt side pillar with boost gauge
Bush wacker fender flares
boxliner, and custom gooseneck hitch
RAMRODD is offline   Reply With Quote
Old 10-19-2009, 11:08 AM   #3
vander
It is likely because of type of use the majority of these trucks get. A large percentage of them are probably used for fleets, and the focus there would be fuel economy not peak hp. And that type of use may also bring a lot more time spent idling, so that is probably the reason for the urea. With more idling, that would cause a lot of passive DPF problems. So a lower peak hp/tq and the addition of urea probably solves the economy and emissions issues for the fleet customers, and other customers can still use the trucks without problems. I'm considering a 4500 for towing a heavy gooseneck, so while I'm frustrated with the two things mentioned in this thread (lower peak output and urea), I think I understand why.
__________________
2007.5 3500 6.7 QC LB 4x4 68RFE DRW
vander is offline   Reply With Quote
Old 10-21-2009, 07:56 AM   #4
Cummins610
Cummins610's Avatar
The 2010 C&C will have urea beacuse of the extended idleing of some fleet trucks especially in cold weather. The lower rating is for reliability and better emissions, the C&C exhaust system is very much different that the pickup and has had less problems.
__________________
2006 CTD LARAMIE - 467HP - 12.97 @ 101.68MPH SMARTY REVO TNT - Autometer Phanton II Gauges - AFE Stage 2 - FASS 150/150 - Quadzilla RP/FP - CFM+ - MBRP 4" - Full Billet DTT Transmission -
2008 Ram 5500 4X4 - 12 Foot Deck - Edge Insight
2008 Ram 4500 2WD
DTR SAC #25
Are You A Diesel Head? Click here to Find Out!
Cummins610 is offline   Reply With Quote
Old 03-09-2010, 10:17 PM   #5
HATCHMAN
The reason for this is because cab and chassis trucks are marketed as commercial vehicles, which causes them to fall under different epa regulations than private use vehicles.
__________________
01' 2500 CTD, H.O. 4X4, NV5600, 3.55, 4x4,Fass 150, 4" Straight, VA Smartbox, Edge Juice w/ Attitude, K&N, Jammer 5's.
05' 3500 DUALLY 4X4, NV5600, SB DD3800, FASS150, BANKS TECHNICOOLER, FIRE RINGED, MOD CP3, FLUX 2'S, HELIX 2 CAM, TWIN HX40-BHT3B, SMARTY, QUAD RACE.
HATCHMAN is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.6.7
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
vB.Sponsors
Copyright 2003, DieselTruckResource.Com
