Go Back   Dodge Diesel - Diesel Truck Resource Forums > 1st and 2nd Generation Ram - Years 1989-2002 > 24 Valve Engine and Drivetrain
Register Forgot Password?
Search
submit to reddit
Thread Tools Search this Thread Display Modes
Old 01-04-2010, 11:09 AM   #1
Junk Man
White smoke on start up - solved
Temp has been in the low 20s at night. The truck was having a difficult time starting & would blow white smoke while it rough idled during warm up. After a little checking I found no power going to the grid heaters. Hmmm...A little more checking and I found the grid wire at the battery disconnected and stored under the battery. Apparently the shop didn't bother to reconnect after the AirDog install. Time for a new mechanic?
Junk Man is offline   Reply With Quote
Old 01-10-2010, 10:29 AM   #2
dansdodgediesel
everybody makes mistakes. It's finding somebody who give a crap.
I had the same problem with mine last year, it was bad connection on the heating grid.
__________________
99 dodge diesel 4x4 quad cab short box 3.55 gear, smarty, low stall converter and transgo kit, ats manifold, MBRP exhaust 4" Thruen track bar.
dansdodgediesel is offline   Reply With Quote
Old 01-10-2010, 01:03 PM   #3
Junk Man
Quote:
I like the people but apparently the help doesn't do as good a job as the owner. They have omitted a few other things and charge top dollar. Can't have it both ways - high charge AND then I have to correct their error.
submit to reddit
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.6
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
vB.Sponsors
Copyright 2011, DieselTruckResource.Com
Contacts Backup
