Thread Tools | Search this Thread | Display Modes |
#1 | ||
white smoke & no power, please help...
#2 |
Check your turbo boots for splits/holes or separation from the tubing.
Check your antifreeze level. If its low you are burning antifreeze from a blown head gasket or worse. Hope for split turbo boot, lower drivers side can rub on body and wear thru after time.
__________________
Kurt 2001.5 2500 QC LB 4WD H.O. 6-SPD SLT Plus 3.54's, Camper/Tow/Plow, A.R.E. Canopy w/ SS Vanguard rack, Southbend clutch and hyd.,TIMBO APPS, BHAF/Heatshield, MBRP 4" TBE, FP Gauge, Femco E-Z Drainplug, DSS, Thuren Trac Bar, 2" leveling kit, P/H Tow Mirrors, PBR, 128K miles. FASS LP "When I was younger I could remember anything, whether it happened or not." Mark Twain Support Our Troops! NRA, MSBL, BYO, GSP, BOLTS, Southpaw, CDC* *Cracked Dash Club |
#3 |
Alright, I checked all rubber boots and there is no turbo leak I can see, and if there was I was thinking it would be black smoke because that is a sign of over fueling.....I also checked coolant level, that is still topped off, not burning coolant. Any other sugestions? thanks for the input!
#4 |
For some reason you get white smoke normally when the boost is down.
That's a plus on the coolant cause that's a big problem. If you can have someone rev it up while you watch the boots, you may find something you missed. |
#5 |
I also think that white smoke can be a sign of injection pump failure. or lift pump failure. I would definetly check pressure going to your VP44 from the lift pump and also pressure from the VP44 to the injectors.
Scott
__________________
'06 2500 QC SWB 4x4 SLT Big Horn, 48re, 3.73s, White Michelin LTX AT2 265/70/17 on chrome OEM alloys Stock. SOLD '98 2500 12V CC LWB 4X4 NV4500 SOLD '04.5 2500 QC SWB 4X4 48re |
#6 |
ok, Will definately check boost. What is the best way? My truck doesn't have a boost gauge, is there a place to screw a gauge into on the intake elbow and check? As far as the LP and IP, is this something it would have to be taken to a shop to be checked? If it is either of these 2 I'm very suprised no trouble codes are coming up when I check. I called "Diesel Power" shop today in Nashville and they want 550 bucks just to pull and pop test the injectors, not to mention how much if they need to repair or replace one, to me that seems high and david the one I spoke with didn't seem to eager to diagnose, he said he would be using the computer diagnostics just like I used......seems expensive to fix a problem that may not even be a true problem.
#7 |
Welcome to the diesel world, heavy trucks=big bucks.
Unfortunately, some repairs are hard to do/diagnose without the proper tools. Call around for a better price, some shops don't make money on the phone so may seem disinterested in helping you out when they have paying rigs on the racks. The vp44 failure code will show up most of the time, but not always. There isn't a code for injector failure though. I understand your feeling about getting the injectors tested, you can get a brand new set of 275's for around $700 so why not just replace them? Although, that may not be your problem. |
#8 |
have you checked for any codes?
__________________
1990 W250 bought new in Nov. 89 performance built 727 and torque converter , high miler 800 k kelderman air ride 2001 2500 HO 6spd 4x4, Engine brake ,fass,SBC 4" turbo back exhaust BHAF fluid damper,ARP head studs, DSS, Fast cools. wife says trucks fast enough:( How many of your rights are you willing to give up before you feel totally safe ?Wake Up People vote EVERYONE OF THE BUMS OUT OF OFFICE! |
#9 |
I replaced the injectors, 3 of them were pretty bad looking, the truck drives like a sports car now, thanks for everyones help!
__________________
2002 Dodge Ram 4X4 6 speed, DAP stage 1 injectors, Diamond eye 4 inch Exhaust, K&N air filter |
#10 |
Nice fix!!
| Display Modes | |
