#1 |
Which brand of tire?
I have a 2000 dually,i'm running 315's with 8 ply tires in the front. I want to put 10 ply on for better wear and hopefully I can get more miles out of them. My question is which tire brand would you guys recommend. If I'm going to spend the big bucks, I'd like to get the best deal I can. I don't do any offroading. Thanks
#2 |
I love my Toyo HT's, almost no weight to balance
__________________
2001 1T Quad Cab 4X4, HTB2/62 Street Stock 12CM-62MM Turbo, Volant Air Box, Flowmaster Exhaust, Edge Juice w/Attitude, Goerend Auto, FASS 150 Fuel System, Ranch Hand Grill Guard, B&W Hitch, Monroe Shocks, Timbrens, Borgeson Steering Shaft, DSS Steering Stabilizer, CC Custom Tailgate, Waag Kickouts A lot of good men have went to Washington, very few have left! |
#3 |
Quite a few people I know are going to Yoko's
__________________
1994 12 valve 4X4 Fully loaded Carli Suspension with 3" Kings Suncoast full billet trans converter & Flex plate HX 40 370 injectors Snow Performance Meth h20 injection 315-75-16 Pro-Comp Extremes Wilco tire carrier Keeps up with the traffic!Thanks to Old Man Bob 4X4 & Pablo |
#4 |
I really liked my toyo ATs I did buy a new set of Micheline for my 01 but I will be buying a new set for my 90 and they will be the TOYOs again ,I just like the feel better and they ran 5 years 70k miles flat across with just a couple rotations
__________________
1990 W250 bought new in Nov. 89 performance built 727 and torque converter , high miler 700 k heavly bombed kelderman air ride 2001 2500 HO 6spd 4x4, Engine brake , mad.ecm mach1.6s fass,SBC 4" turbo back exhaust BHAF fluid damper,ARP head studs, DSS, Fast cools.snow w/m, wife says trucks fast enough:( 335 hp/800 tq) How many of your rights are you willing to give up before you feel totally safe ?Wake Up People vote EVERYONE OF THE BUMS OUT OF OFFICE! |
#5 |
Just a quick point: there are no actual different number of plies according to load rating. Many folks think C=6, D=8 & E=10. The only difference is the structural rigidity of the sidewall which coincides with the load capacity. Not a difference in number of plies. Just a pet pieve of mine, kinda like when folks refer to anything that is powered by internal combustion as a "motor". Engines are powered by fuel & motors are powered by electric. Someone once asked me what kind of motor I had in my truck and of course & had to ask if they were asking about soleniods or a fuel pump. I'm just saying...
__________________
'02 Auto, 4.10's & 35's, 114,000 miles, Goerend triple disk, valve body & strap anchors, FASS 150 HPFP, HOT Juice w/ Attitude/Smarty stack, Stage III Jammers, BD Super B single, ATS 3 piece manifold, BD intercooler boots, AEM Brute Force intake, 5" turbo back straight exhaust & Timbo APPS...so far |
#6 |
I like my Yoko Geolandars. Much better in every way than the OEM Michelin's, IMO...
__________________
<---My previous oil burner "Bombs delivered on time or your money back!" ------------ '01 2500 SLT Laramie QC LB 4x4 Auto 3.54 gears 230K miles. Goerend w/billet input shaft/ low stall TC/ 2,3,4lockup+switch, 4" exhaust, Edge Juice with Attitude, Superchips 3705 Tuner, Walbro 392 with Swagelok bypass, Yokohama Geolandar 315/70R17s on 2006 H2 LE Alcoa wheels, '03 front brake conversion, PSC Steering Stabilizer. '09 Northstar 850 SC XB popup slide-in camper Semper Fidelis! |
#7 |
Thanks for the reply, I didn't know if I should go with a 10 ply , so I could pump them up to 80-100 psi. I figured with the two on the front that the weight of the engine the truck would roll easier down the road and get a little bit more fuel mileage. Tires on the front wear out really fast. I can't rotate the tires because the wheels on the front are a little different than the back. Anybody have a preference on tread design?
#8 |
I have had pretty good results with Nitto terrra grapplers load rang E. They are also 10 ply.
__________________
01 Cummins 4x4. Edge Juice w/Attitude, HTT Stage III quickspool hybrid HX35/40W, Airdog II 165, 40hp Edge jammers, Byrd's Diesel intake, B&D heavy duty auto trans with lockup, MBRP turbo back 4" with dual 4" black turn outs, Airaid cold air intake and Pac exhaust brake. |
#9 | |
Quote:
__________________
'07 2500 Reg.cab,G-56,5.9, Northstar popup 24/7. Upgrades: Carli,Defiant,Thuren,King. Don't blame me,I voted for McCain. |
#10 |
toyo, i like m-55s.
__________________
96 4x4 3500 extended cab - modified. 86 4X4 land cruiser - air lockers, lifted & winched. |
#11 |
I think I am going to Yokos next. I put geolander ATs on my wifes crv. a couple of the tires took less than .5 oz. and the rear driver took NO weight! balanced perfect on the machine, couldnt believe it. Seems that their quality control is A+.
Been seeing a lot of yoko tires on 3/4 and 1 ton rigs lately.
__________________
'98 2500 12V CC LB 4X4 Laramie SLT, NV4500, 3.54s, LS Dif, Black/silver KDP killed, AFE CAI, Bridgestone AT 285/75/16 E Luverne steps, Leer Browning ed. shell, Defiant Steering Box Support, Luk Pro Gold Clutch, PacBrake http://www.dieseltruckresource.com/p...m/98_12v_3.JPG SOLD '04.5 2500 QC SB 4X4 |
#12 |
i put geolanders on all my vehicals. no added weights i just use balance packs in all of them. the packs are the way to go. no more white rust on your rims.
__________________
01 dodge diesel reg cab SPORT 6sp "sbc dd 3600" super64 smarty tst 110h over injectors 5" exhaust afe2 fass150-150 water meth dipricol gauges 271 club hmmm "still stock" 219000 and still going on the same old motor. just got done rebuilding her after a encouter with a cow. dodge won kinda. but i made her into a sport she looks much better. as for the cow. DOA |
#13 |
I like mine also. Drop the air pressure if they wander - then they are very nice. Discount tire will price match web prices. $642 out the door for 4 about a year ago.
__________________
2000 2500 Quad Cab 4X4 LWB 5 speed 4.10 gears, gauges, AirDog, DrawStraw, External Oiling system gone - thanks FixinRams. Thuren 3rd Gen Track Bar (beautiful), DSS, RockSolid Bushing, AGR Steering box - will try something else next time. POR 15 covered with Rustoleum that color matches until I spring for body work. Tuner & sticks next. |
#14 |
Any major tire store should price match to tirerack.com. They'll add in the shipping but still come in hundreds lower than their in-store price.... Still love my Yoko Geolandar HT/S rubber. They start out whisper quiet but get a little louder as you wear down the slots and slits (in a non-gender biased, politically correct sort of way, of course)....
#15 |
I would look for something with a solid tread on the outer lug near the sidewall, this will help to keep it from cupping, nitto advertises such a tire on the back cover of magazines, looks like your gonna have trouble finding a street tire in that size.
__________________
2001.5-3500 SLT 4x4 Quadcab, stock, 5 speed with 3.55 gears, lowered aluminum flat bed, 4" MBRP, silencer ring mia, 255/85-16 tires. |
| Thread Tools | |
| Display Modes | |
