Thread Tools | Search this Thread | Display Modes |
#1 |
WH1E exhaust flange question?
__________________
86' GMC 3500 (cummins swap: hx40, POD's, I/C 5" exhaust, 3200 gsk, pump tweaks) , custom 4-link front end, about 9-inchs of lift, dana 60 4.56s welded/ 14-bolt, 4.56s detroit. 40x18.5 Bajas, custom frt/Rr bumpers, 16.5 super sinlge welds |
#2 |
I believe htturbo makes an adaptor, but its pricey.
__________________
89 cummins conversion into 1979 f-250, dual electric fans, four core rad, valet switch, htt stage IV, 16cm nwg, ground fuel pin, home-made dual intake manifold, 3 inch crossover, pods, 1/8 inch timing advance,pump tweaks, holley black fuel pump, Eaton/Fuller 5 speed. |
#3 |
yea thats what i just came across. they want like 150 bucks. looks like im fabbing my own up. i'll post sum pics incase anybody else needs one. i mite beable to hook ya up
#4 |
I thought it was pricey
#5 |
ok guys made me up an adapter today. only took me about 5 hours. alot better then dumping 150 bucks. well here sum pics of it. let me know what u think. i plan on tapping it for pyro, and adding a few ribs to it for extra support. i do jump the truck, so i dont need that thing ripping off
#6 |
Looks good to me.
__________________
Faith '93 D350 - DPS 6x16's, HTT Stage IV/14wg, PowerStroke IC, Snow water/meth, Walbro 392, Con-FE, pump tampering by owner. 390 HP/800 TQ on #2 only, 413 HP/852 TQ w/ water/meth - needs more air! Dead KDP's = 72 |
#7 |
thanks wannadiesel
#8 |
Good ole' T3 to T4 flange. What size is the exhaust housing?
__________________
--91 D250--5 speed, 3.07s, SBDD 6-puck, Scheid 14mm VE (no KSB), DDP5x16's, custom IC, 3.5" boost tubes, 64/12wg turbo, 19 gallon fuel cell, .040" Mahle Marine Pistons, 60lb springs, hardened pushrods, A1 H11 studs, Ported head, Valve seats and valves cut, 10lb bottle of go juice. |
#9 |
its a 19cm. i know everybody says i should ditch the turbo, but im planning on towing a pretty heavy mud truck behind it so the bigger turbine mite be nice for those long hills. do u know where i can find a 16cm? if the 19 is to laggy
#10 |
you can buy the adapter on ebay for $55
http://cgi.ebay.com/ebaymotors/CAST-...spagenameZWDVW i'm pretty sure it's the same thing |
#11 |
This definately is not a towing charger. Play truck only, more of a door stop, but if you don't have much in it, you might contact a Cummins/Holset dealer to price a 16cm t3 housing for it. Good luck finding a 16 housing for a hx40 used, ain't gonna happen. Everybody that has picked up a doorstop hx40-19 or h1e-19 new/ebay or junkyard is looking for a 16 housing to make it a useable charger.
__________________
Bill Gilbert 85 D350 crew with 90 6BT intercooled Getrag 3.07's 93 D350 single cab Getrag 3.54's |
#12 |
well i work next to a cummins dealer so i'll checkthat out. but y wouldn't it be good for towin?figured super low egts and y good for a play truck? if its a lagster? my towing is mostly gonito be highway, like nj to florida, or nj to mich. with a trailer full of quads or a truck. please explain sum more. thanks
| Display Modes | |
