#61 |
As I was installing my Wilson intake I said to myself, now would be a good time to drill & tap the intake plate for water nearest to 1 & 6 . Did I, no I felt maybe I was being to particular. (anal). Well maybe I should have.
Like ever thing else, looks like Ill be doing it twice. SOB. But OK where does the water go it it doesn't make it to 1&6 the intake plenum is nothing more than a tank. The intake valves are only open a short time. Taking what they can handle . The water spray is constant under boost. How is it not getting there.
__________________
2004.5 , MPI 62/71 over 80 mm Helix 2 , Walbro, 4 " duals, optix, Mass Diesel billet DTT , Flex plate, Flux 3s' Floor it 3.5 pump, TNT-R ,HTT intercooler, Wilson intake , Lorenz leafs, Carli Coils , Arms, Thuren kings, Steering, Track bar DSS,Opie bypass,Water injection, |
#62 | |
Faux Devils Advocate
Quote:
Those that feel the water is not getting there in any usable quantity think it is due to the turns and angles the air/water mixture must travel and this causes the water to be shed from the air and results in more being ingested by the ports that are more in line with the intake horn. Most of these people are also running massive amounts of water and they may not be atomizing it completely. Six nozzles with one in line with each intake port is best, as long as you get proper atomization you will get plenty of water to ALL the cylinders when injecting from the intake horn.
__________________
2006 Megacab 5.9L CTD Edge Juice and Attitude S&B Cold Intake and intake elbow Cooling Mist water injection with VariCool II ISSPRO Gages (A-Pillar) Boost, EGT, Fuel Pressure |
#63 |
I've never had the plate off. Is there proper spacing/room to install a nozzle over each intake port?
__________________
Flux 5.1's, F1 springs, F1 Helix 2, studs, HTT Intercooler, Evil-Twins over Floor-It stage 2, SMARTY Beta 4.2, MPI 62-14/GT42 Twins, Opie bypass, MBRP 4" exhaust, Walbro with Aeromotive regulator, Goerend trans., Cooling Mist w/ dual pumps. 787 HP @ Mid-Atlantic Diesel 6/13/09 |
#64 | |
Quote:
So has anyone tried this yet?
__________________
06 3500 SRW LB Special Thanks to Lloyd @ Mid-Atlantic Diesel SBC 3600 Sprung Hub Optix Gauges ED 64/71/13ss Floor It Stage 3.5 (IN THE WORKS) Opie's Bypass Hamilton springs Hamilton cam S&B ARP studs TNT-R/MP-8 Mitusa Next is Mofia 120's Trey Alan Swope born 11/7/09 |
#65 |
What scares me is the posts about all these Common Rails melting pistons. I know I have enough fuel now to melt things down in a hurry and my twins are on the small side.
I'm thinking I could buy smaller nozzles and buy 3 port blocks and run three smaller nozzles on each pump all tapped into the plate above the intake ports. Anyone care to comment? |
#66 |
yes I installed a nozzle just past the plate between the adaptor plate and the motor lift mount. I had to us a right angle drill and really take my time to get the tap started straight.
__________________
2004.5 3500 srw stock and hoping for mods soon |
#67 | |
Quote:
Rob |
#68 | |
Quote:
#69 |
#70 |
#71 | ||
Quote:
Quote:
Any system leaving unburt or unvaporized water in the engine after injection is ovbiously going to do this. And it follows of course, if you are going to do that, then you do need an anti-rust additive. And frequent oil changes. And the occasional rod and/or new block when an unintended side effect happens to occur after the miscalibrated or poorly designed system ventilates the cylinder wall with a rod for you. You guys are on the hairy edge of experimentation with this stuff. Great - more power to you! I mean that literally. ![]() If you ever get it "right" (and I use that term loosely - please define "right" however you choose to have your truck running, drinking, whatever), you will have all six cylinders runnnig cool at the same temp at WOT and no water leftover in your engine after a good spray. The anti-rust is a band-aid for a symptom nothing other than a throw-away engine should ever be subjected to. Now please, also tell Bswope exactly how to get it right! (the way he likes it) ![]()
__________________
'91.5 W250LE, G360, 4.10, GV OD -366GS, 160gph Pump, 50gal. +Fuel -Onboard Air, Water/Meth, PacBrake, Mag-Hytec -Tach, Boost, Pyro, Fuel Pr, Altfuel, Oil Pr, Trans Temp -34" Dura Grapplers w/17x8 Alcoa Classics, RS9000XLs -Borgenson, Fr&Rear Sway Bars, Skyjacker, Timbrens, Torque Links -GC-01, Fuel Cooler/Racor Filters, Trans Cooler/Filter, Steering Cooler/Filter, Engine Coolant Filter -Ram CAI, Coolertubz, GDS60mm/12cm, Hardened BD Fuel Pin, PSIC, ATS Mnfld, Full Magnaflow 4" Exhaust |
#72 |
he told you that the rust was discovered when he only had the snow system installed with 2 nozzles only into the intake horn. same thing that I told you when it happened to me. Miss That Part????
#73 |
Nope. You are obviously not listening to anything I've said, so I'll just agree to disagree, it's a matter of principle - Bye again!
#74 |
#75 | |
Quote:
![]() Here you go: BYE! |
| Thread Tools | |
| Display Modes | |
