#1 |
Wasilla is 3.44 a gallon !
man if it keeps this up im going start having pimp out the wife !
#2 |
I live in Nevada. Price per Gal here is $3.39. Talked to my Dad Last night who lives in Wasilla AK. Was not to much of a difference. I DONT GET IT>
__________________
2006 Quad cab 4x4 1ton auto 3.73 gears Muffler delete, 2" leveling kit, Firestone Ride rite air bags, Cool blue intake tube and air box mod. |
#3 |
every station in town is the same price so their is no breaks .. 3.44 and 9/10
i live just outside wasilla and have to drive to anchorage daily its starting to hurt ... and this new desiel fuel really sucks ..winter already sucks for fuel mileage here with the warmups and all .. heating oil here is 3.11 gallon ! im really glad i switched to natural gas 2 years ago ..that would hurt 3.11 x 500 gallons ! |
#4 |
Wayne I, Is Meadow Lakes AK Near Wasilla? How Far are you from the new Sportsmans Wharehouse. Just curious. My parents live in Wasilla.
#5 |
CA prices are 3.59 and up.
Dan
__________________
'06 Laramie 4X4, SWB, Jake w/ Dash Switch, AMP running boards, Valley slider hitch, Isspro Gauges, Jordan Controller, BD Cooldown |
#6 |
That "heating oil" is the same stuff you put in your truck you know. You need to get a tank in the back of your truck and fill up"fuel oil" at Fisher's fuel. Just a thought
__________________
2005 Silver Ram 3500 SRW, QC, LB, 3:73 LS, Auto, SLT+ 1990 F-350 ReG cab w/ 97 12V NV4500, #10, 3kgsk, 4" SP, SB Con OFE |
#7 | ||
Quote:
__________________
-40* keeps the wimps away but I WANT A (BIGGER) GARAGE! 92 CTD Club Cab 5spd. Banks 14cm w/g turbo, 3.5" exhaust, pyro/boost/oil pressure/coolant temp/trans temp gauges, 190s, 3200 spring, pump tweeked, Hot-wired KSB, K&N, add-a-leafs and airbags. 225K & still rollin' Proud Member- Alaska Correctional Officer's Assciociation. "Walking Alaska's Toughest Beat" Quote:
#8 |
#9 |
just filled up yeasterday in soldotna 3.55
__________________
97 dodge 2500 , 7" single grandrock miter, k&n cold air, 100 plate, 4k gsk, fass 150/150, snow stage 2 water meth, arp studs, marine gasket, htt 62/13/71 ]ss,htt 3 piece manifold, DDP stage 3 sticks, lazer cut dvs, sb dd 3250 . timing at 18* o-ringed head with 5 angle valve job & 60#valve springs, pdp intake horn. |
#10 |
Not bad.
Heating oil is $3.32 here, diesel is 3.70 |
#11 | |
Quote:
__________________
Protecting the constitutional principle of the separation of state and church 2006 Ram 2500 CTD QC TRX4 Winterized for Arctic conditions... 2 Heated Battery Pads @ 60 watts each Engine oil pan and Transmission pan heaters @ 150 watts each Engine Block heater 750 watts Bank of 4 Moose Lights on a Randy Ellis light Bar DeltPro 77 gl. fuel transfer tank plus storafe Dueler A/T REVO's with UNI-T AQII Technology For Security...Ruger Red Hawk 44 mag and 11 year old German Shepard/Husky |
#12 |
DTR's Toad Wrangler
Now that is funny, I will be looking for a place where I can use that line
__________________
94 Dodge SLT 2500, 4x4, 5 speed,dual friction clutch, 100 plate,AFC and plate full forward, A pillar boost and Pyro gauges, 4" exhaust, K&N FIPK with outer wear, Pac brake, Frantz Oil cleaner, Firestone air bags, Rancho 9000 shocks, GM rear brake cylinders, rhino lining, home made DSS and a bunch of stuff that I can't remember |
#13 |
so wayne how much down there now? I know you've been up here an seen the prices. Mostly around $3.44 in fairbanks and North Pole is about $3.67. Last winter it hit over $5.00 in north pole. Man I hope that doesn't happen again.
__________________
2005 3500 SRW QC CTD Laramie 4X4 |
#14 |
3.80 in Delta for last week or so...
#15 |
What the hay! It is still $3.51 to $3.59 in Palmer. Were in Wasilla?
__________________
91.5 W250 4X4 5spd 3.07s 16cm2 M2 BHAF Bosch +40s GDS 60mm turned up 92 W250 4X4 3.54 Xcab auto bonehead stock |
| Thread Tools | |
| Display Modes | |
