Thread Tools | Search this Thread | Display Modes |
#1 | ||
__________________
01 2500 Q/C 4x4, factory order HO w/5spd, 4 wheel discs, Pacbrake, 285 nitto HD grapplers on 17" eagle 186. Ultra 5th wheel hitch. Glacier Diesel GFS-392 LP 01 F550 XLT 4x4, replaced by a fleet of reliable mid 90's gmc trucks, with 6.5 diesels and 5 speeds. Old, slow and in denial, just like me... |
#2 |
just wondering,, but why not take it back to the selling dealer if they are stading behind it?
__________________
The newest addition to the family 1/20/2010 a 2007 dodge ram mega 6.7! Smarty/edge combo solid axle manual hub conversion, bfa, and soon well be doing some nasal reconstruction! New baby as of 7/24/04 2004.5 Ram 2500 4x4 silver diesel. 600 cummins. All the nice lil electrical things that will die in about 5 years haha. Stock and with these payements at 20 will stay that way 97 4x4 360 99 CTD 4X4 intake and exhaust, |
#3 |
Seems to me that you might need to develop a "bad lift pump" in the very near future
__________________
"SHIFT OR LIFT [deadhors] YA OLD SLUG" 01' qc 4x4 5sp.roughnecks front and rear, afe screamin' whistle intake,4" well muffled exhaust, jammer2s,real fancy intercooler, silencer ring mia, superchips, van aaken v5 replaced by drag comp, carter pusher,vulcan super high flow fuel system, 21mpg! ISSPRO EV"s fp/pyro/boost, SHE BREATHES AND SMOKES WITH THE BEST OF EM' |
#4 |
Sorry about that guys, I forgot to mention that is has developed 4 "bad" lift pumps in its life span to date of slightly less than 140,000 km.
And as far as returning it to the selling dealer, they are located approximately 2,200 km, or say 1,350 miles from where I am, with a whole bunch of not too much in between. With the truck acting up the way it is, I am stuck with the local dealer, or no support at all. ( starting to think this means the same thing? Hmmmmm?????? )So that is where it stands. At this point, I am not taking the truck on any road trips. The thought of breakdown doesn't bother me, I work on broken down stuff every day, and the thought of camping out on the side of the road at -20 to -30 C doesn't bother me, as I go prepared. The problem I have, is being without a service truck. Not so cool, and the tow bills are horrendous. Enough ranting, just looking for random thoughts on the pump. |
#5 |
maybe the harness will fall off your lift pump while you drive around the block a few times and that will throw the code you deserve
#6 |
Hmmm, I thought that "most" times when IP's failed they threw a code?? All the failed ones I've seen (just a couple) had codes and check engine lights. That sucks!
__________________
'06 2500 Mega Cab, New Feb '07, 4x4 SLT loaded, 6 speed, Sun Roof, all the goodies, B&W Gooseneck hitch, Prodigy Controller,Stock so far. 160,000 Miles Towing 2009 Sooner Ranch SR724 Stock trailer Sold: '99 2500 Quad Cab 4x4 5spd. 24V CTD Short-box, Sport, Loaded, 30,000 # Draw-Tite Gooseneck hitch, stainless flares and grill insert, silencer ring gone, straight pipe with 6" tip. BHAF, Van Aaken Smartbox. 250,000 miles DTR Mega Cab Club member #9 |
#7 |
Mine never threw a code or lit the Check Engine light, it just died.
It was gradual, over the course of a couple weeks, since there were no codes, it took a couple trips to the Dealer for it to finally exhibit symptoms in front of them. got it replaced at 4,000 miles on the clock. Lift pump was and still is fine, 40,000 miles later. phox
__________________
2002.5 Dodge Ram 2500 4X4 SOLD 2009 Jeep Wrangler Unlimited X 4x4. Detonator Yellow in color Bone stock for now, at least for a couple months 2008 Harley Davidson FLHR Road King. Black Pearl in color 12 inch apes, stainless cables, Vance & Hines pipes, garage door opener, combo speedo/tach |
#8 | |
Quote:
X2
#9 | |
Quote:
X3
__________________
2003 3500DRW QC Laramie 4X4 NV5600 4" Superlift~Rumble Bee Scoop~FASS 150~Dr.P/Smarty Stack~SBC OFE~Performax Gauges~BD Brake~AFE II~DTT Intake~Audio Addicted __________________________________________ Sold 1998.4 12V LB/QC 2500 4X4 AT PDR Twins Helix II 913 modded pump __________________________ Sold 1998.5 24v LB/QC 2500 4X4 AT PDR Twins Comp-Hot __________________________ Wifes car 04 Jetta TDI Sport ___________________________ GAS IS FOR WASHIN PARTS |
#10 |
if u are a cummins mechanic cant u use the electronic handheld pump tester that u plug directly into vps ecm? if u want to destroy the vp yourself fill the filter housing with alchol a few times till pump dies then drain it and refill with diesel, the bring to the dealer.
__________________
99 auto 4x4 4.10 rear,no s ring,bhaf, edge ez, 4" s.s. magnaflow 05 Q.C. auto, stock....for now... |
#11 |
How far did you drive it with bad lift pump?
#12 |
Ok, to answer questions. First, I have tested the vp44 on its own, with the proper scan tool. The pump is working somewhat soundly on the electronic side, hence it not throwing codes. The injector knock down test reveals that each injector is getting a balanced amount of fuel. Driving, there are some erratic timing issues, but it still does not throw a code, leading me into the mechanical side of the pump, or a gremlin I have yet to see. Referring back to the fact that of all the VP44 pumps I have changed, very few threw a code. yet all exhibited similar, and in several cases, exactly the same symptoms, that I am seeing with this one.
As far as cratering the pump. Right track, wrong train. I have taken apart enough IP's to know what they look like when they have swallowed something that they shouldn't have. Alcohol is a bad idea, as it dries the pump out, causing galling, scoring, and an eventual seizure, followed by twitching. Usually the owner does the twitching when they are told that they did something that directly contributed to the failure of the pump. Proving it can be a pain, but, in my little world, there is something called being ethical, and accountable. Being one of those rare "honest" mechanics, still means something to me. As far as distance goes. First LP that went south, I was about 40 miles out of town, hauling a 5 cord load of firewood on a tandem trailer. it started out fine, and as I got closer to home, it suckholed more and more. Didn't take a rocket scientist to figure out what was wrong. Called the dealer that night, and got a new one the next day, dropped it in. VP pump was still happily functional. On average, as the LP's kept blowing up, I would have to drive 15 to 30 miles with dysfunctional pumps. Not by choice, rather by necessity. Now, every 5000 KM, I change the oil, and oil, air, and fuel filters as well, as I have since I bought the truck new. As well, I test the LP pressures every oil change since the first LP failure. I have not installed a gauge in the truck, as it never runs truly empty, so there is always a bit of a load on the engine, enough to clearly indicate a bad LP. Handy handy handy. Hopefully this gives some of you a baseline to work with. Happy hauling |
#13 |
Top's Younger Twin
I had 4 failed injector pumps on my 98.5.
Two were mechanical failures...no codes. Number one was on I-15 from Calgary to Vegas dragging two trailers. Truck felt like it was shutting off and then BANG...trying to catch up. REAL nasty feeling...no codes. Made it to Vegas...changed VP-44...it was full of filings. Pump two...codes. Was a dud from the start. Got 10 mpg with it empty driving back to Canada. Pump 3, codes. Same as above. Pump 4, no codes, no jerking or stalling...just quit, no start right from the first time it stalled. Internal parts looked like they had been beaten with a hammer. Sold truck and went to an 01 shortly after...killed a VP-44 on it too...this time is was because of someone being overzealous wanting to tap the pump with a few too many turns of the screw and cracked the circuit board. Its very possible to have no codes. The dealer in Vegas had seen it before and changed it the day I coughed, sputtered and smoked into their service drive.
__________________
#14 |
would a broken diaphram not let the vp build pressure but also not show a code
#15 |
I dont know about codes.... but she might get knocked up
| Display Modes | |
