Go Back   Dodge Diesel - Diesel Truck Resource Forums > 1st and 2nd Generation Ram - Years 1989-2002 > 24 Valve Engine and Drivetrain
Register Forgot Password?
Search
submit to reddit
Thread Tools Search this Thread Display Modes
Old 05-08-2005, 11:26 AM   #1
MnTom
MnTom's Avatar
Question VP Question
I don't have a VP, but I do have a question. Since the VP does have an overflow valve, if it failed (lost spring tension or leaked through) would that 'starve' the VP? What I am wondering is that since the fuel like any other fluid will take the path of least resistance, the fuel would go back to the tank instead of going where it was needed in the pump. This would have the same effect as the LP failing wouldn't it? I have been thinking about this for a while and have not been able to reach my own conclusion. Any ideas or thoughts?
Tom
__________________
SUPPORT OUR TROOPS
'96 Ram 2500 2wd auto, EGT, boost, & tranny temp gauges, timing at 16.5*,BHAF, #8 fuel plate slid 3/4 forward, AFC 3/4 forward too, Piers upgraded turbo, kdp tab fixed, Goerend Tranny, 15" long glass packmuffler, set up for 24' '06 Dutchmen 5th wheel and 16' boat behind 299HP 678TQ -U/A local 11-
MnTom is offline   Reply With Quote
Old 05-09-2005, 06:51 PM   #2
rockwithjason
rockwithjason's Avatar
Well, common sense would say that a whole lot of fuel would bypass to the tank and fuel pressure would drop in return. I would think that you would starve the pump or at least limit the fuel supply.
__________________
new rig: 00 2500 x-cab, 4WD, autometer boost fp trans and pyro, step bars, revelco, jimmy jammers, 03TBK. here we go again!
STOLEN!!00 2500 x-cab 4WD,
IBEW lu 357 Build it Union!
Union Wireman get in your shorts!
Member of Gun Owners of America
The only no comprimise gun orginization
rockwithjason is offline   Reply With Quote
Old 05-09-2005, 08:02 PM   #3
JAFAW
The fuel flows in under the computer to a internal supply pump ( Which makes 30 to 350psi depending on rpms) then to the rotor head or advance piston then what is not sent to the injectors is used for cooling and returned. Even when the pump is not firing (like coasting down) fuel is pushed thru to cool the pump. that is why the truck runs for a short time after the transfer pump fails
JAFAW is offline   Reply With Quote
submit to reddit
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.6
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
vB.Sponsors
Copyright 2011, DieselTruckResource.Com
Contacts Backup
