Go Back   Dodge Diesel - Diesel Truck Resource Forums > 1st and 2nd Generation Ram - Years 1989-2002 > Performance and Accessories 2nd gen only
Register FAQ DTR Store Members List Mark Forums Read
Thread Tools Display Modes
Old 01-23-2006, 09:30 PM   #31
dodgezilla04
ever try to remove a glow plug that has been in there for some time and has carbon built up around the top of it? Hope like heck you can turn it enough to remove the carbon, or you will break it off and the only place for the tip to go is on top of the piston. Now your only choice is to pull the head, or to start it and wait for that horrible sound to stop before it hangs up a valve. My buddies 6.2 made a racket for about 5 minutes. That darn motor just wont die!!! 325k miles on the clock.
dodgezilla04 is offline   Reply With Quote
Old 02-19-2006, 10:04 PM   #32
cody@nl'sCTD
Send a message via MSN to cody@nl'sCTD
Yes Fords i know have the glow plugs, but im not 100% sure aboud the chevy. A downfall to the glow plugs is if they go bad and its cold it may be difficult for the truck to start in cold weather. Im a Dodge man my self, no glow plugs necessary. I think the fords have 8 glow plugs and im not sure on the price to replace them if the would happen to go bad
cody@nl'sCTD is offline   Reply With Quote
Old 02-20-2006, 03:43 AM   #33
2500CTD
2500CTD's Avatar
Quote:
Originally Posted by KATOOM
can get a device that overides this feature to save the grids from unecessary cycling when the engine is warm.
So where is this device. Is it really needed? Do the heaters ever wear out??
__________________
2001 4x2 2500 QC short bed auto, 3.54's. Smatry #5,GB tranny,Scotty 2,Rips 4" straight,BD XMonitor,275 infectors,F/P w/ isolator, Rear Foglights, Sportlights. Fast Specialties Dyno day #1: 257/507, Dyno day #3: 274/580
2500CTD is offline   Reply With Quote
Old 02-20-2006, 05:35 AM   #34
Chrisreyn
DTR's Night Watchman
Chrisreyn's Avatar
I had a Ford F350 with the 6.9 before I got smart and traded it for my Dodge.....
I had to replace the glow plugs three times in three years...
They are comparable in price to spark plugs and change out about the same, alibeit a little more difficult to access...
When, not if, one breaks off and falls into the preheat chamber( the ford 6.9 uses a small air chamber above the valves to preheat the air in) you either pull the head or get a flexible magnetic pick-up tool and spend hours "fishing" to retreive it..... been there done that...twice.....
__________________
93 D350 XCab, engine pretty much stock, BHAF, RV Torque Convertor, Air-Ride Suspension, muffler MIA,
Chrisreyn is offline   Reply With Quote
Old 03-02-2006, 07:28 PM   #35
pluguglyinhere
Just an added note in the newer trucks (mine is an 06), actually I ahve no idea on any years but the 06 sorry. I had the dealer for free turn on my additional high idle. Now in the cold mornings I start the truck set the Emerg brake and turn on the cruise and I can idle up with the accell/decell for warm up. The added RPMs keep the juice flowing so no dimming. If ya put it in nuetral the tranny circulates and warms it faster also. This was from cummins supposedly stated from my dealer.
__________________
2006 CTD Ram 2500 Quad Cab 4x4, issipro tranny, egt, and boost in the a-pillar. Aero turbine all by its loansome to give the rammed air someplace to go.
pluguglyinhere is offline   Reply With Quote
Old 09-26-2006, 10:09 AM   #36
54larry
Doh!--I just asked this very question
Shoulda read the board first!
54larry is offline   Reply With Quote
Old 12-09-2006, 05:27 AM   #37
Katmandu
Katmandu's Avatar
Question
Anyone know why Dodge/Cummins hasn't done something about the electrical current draw down during heater grid cycling at engine IDLE speed ??
It's NOT an issue when the engine speed is above say 1500 RPMS when the Alternator is putting out FULL Power, but as well ALL know the Alternator does NOT keep up with the electrical load during this time.
What are you're all thoughts on this ?
__________________
1998 12 Valve, loaded SLT Laramie, QC, Short Bed, 4x4, 5 Speed, Leather, #10 Plate, 3K GSK, BHAF, Timing 16.5*, Waste gate Blocked, AFC Forward, 4" Straight Exhaust, Turbo Silencer Gone, KDP Killed, '03' Track Bar, DSS bar, 3.54 LSD gears, 285/70 Revos. 400 HP/923lbs TQ
Click the link below for some pics.
http://katmanduonline.net/pics/98_Ram_CTD/
Katmandu is offline   Reply With Quote
Old 12-09-2006, 06:00 AM   #38
Shovelhead
Shovelhead's Avatar
The system they use has been working fine for this long, why mess with success.
After all, we could have glow plugs. (and all the problems that go along with that)
The heaters stop cycling after you drive to ~25 mph.
Also Cummins doesn't recommend extended periods of time idling at cold temps.
A fast idle has been incorporated into the newer model years.
__________________
Ed Anderson
'99 3500 SPORT BlackClick for Picture Gallery
Isspro EV gauges, Fuel Pressure{mechanical}
DTR Site Moderator
Shovelhead is offline   Reply With Quote
Old 12-09-2006, 06:24 AM   #39
Bigdenny
If I remember right, I think the heaters draw about 90 amps.
Bigdenny is offline   Reply With Quote
Old 12-09-2006, 08:15 AM   #40
b4wheeler
b4wheeler's Avatar
I actually heard 200 amps.....
__________________
2000 Dodge Ram 3500 4x4 Dually Sport, Loaded
53 Block, BHAF w/shield, Vulcan Big Line Kit, Holley Blue fuel pump, Draw Straw II, Van Aaken, Quadzilla Xzillaraider (stack), DD3 Injectors, 4" Straight Pipe, Autometer Pyro and Trans gauges, Isspro FP and 60psi Boost gauges, HTS Ultimate Duty 47re HTS47--1, Geno's Oil drain thingy
Maryland DTR Chapter #33
b4wheeler is offline   Reply With Quote
Old 12-09-2006, 11:05 PM   #41
BuyAmerican
WOW!! TOO COOL!!! I just had to replace both die hard bateries that were in my truck when I bought it back in 01. Then when I started it up, the Mrs. and I noticed the dimming headlights and drop on the volt meter. I told her that this was probably the alt and we will soon lokng for a new one. NOW!!! I read this and told her about it and she is again, impressed with this truck!!! (ME TOO!!!)
Thanks guys.
__________________
96 2500 4x4 auto, silencer ring M.I.A. K&N air filter, towing an 86, 26' Kit RoadRanger Elite 5th wheel, Goerend tranny w/ billit input, valve body, triple disk tc and DD pan. Idle set up to 750-800 RPM.
KDP FINALLY TABBED!! (only had 187K mi on her...)
Wish list; 3kGSK, Gauges, fuel plate (still researching which would be best...).
Still reading this site regularly.
BuyAmerican is offline   Reply With Quote
Old 01-11-2007, 04:57 AM   #42
deuceandahalf
deuceandahalf's Avatar
Quote:
Originally Posted by KATOOM View Post
Just thought I'd mention that I dont think GM or Ford uses glow plugs.
Hmmm - don't know about the Duramax, but prior GM's do have glow plugs, and believe me - they gotta be working to get 'em started...
__________________
'99 R3500; 6-speed; PacBrake; injectors; 4in. exhaust; AFE air; EDGE Ez; ISPPRO pyro/boost; ATS propane; Glacier L/P – MWFI VP44; Line-X; added 2 ton to overloads and 800# to mains; 300/600 Dyno. Pulling a 53' dropdeck, 4-horse GN, etc. 165K as of 05/12/08
Troop Supporter! NRA Lifetime (and, oh yeah – I’m a bit hawkish)
deuceandahalf is offline   Reply With Quote
Old 01-22-2007, 06:33 PM   #43
blackquad
is this fused so that you can disconnect it?
blackquad is offline   Reply With Quote
Old 02-16-2007, 11:49 AM   #44
silverbullet830
silverbullet830's Avatar
yeah yesterday morning it was 34. only had my truck a week today. i was sitting there and saw my gauges and radio dimming and the votage dropping just a little bit. been wondering what it was. now i dont' have to worry bout it! good thread guys!
__________________
2002 QC 4x4 2500 White/silver 2 tone... silencer ring removed. stock otherwise. but i do have some plans........
silverbullet830 is offline   Reply With Quote
Old 04-15-2007, 01:28 PM   #45
Ground Shaker
Ground Shaker's Avatar
Send a message via AIM to Ground Shaker
Shovel, since you posted it I figure you'll know about it. I know Cummins doesn't recomment the higher idles for long periods but the fast idle on the new trucks, does that have an automatic shut off after a period of time or after it hits a certain temp?
Also, sicne the ford boys have been dropping in, I was wondering if any of ya'll knew if the new 6.4s have glow plugs or heating grids. I have heard things both ways but haven't witnessed it first hand. We still don't have any 6.4s in the area, nor 6.7s so I'm still waiting to get my hands on both. Thanks guys.
Ground Shaker is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.6.7
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
vB.Sponsors
Copyright 2003, DieselTruckResource.Com
