Vibration/ shimmy at highway speeds
Thanks WD!... any chance you could define "coined"? I asked (not of you) in an earlier post and don't recall seeing an answer...
I *think* it might the term for the 2(?) stamped "slots" (male/female) that run radially between the lugholes on the rims... or am I way off
Like leper said. Alternating "cups" and "cones" around the bolt circle. They interlock when you put the rears on correctly and keep the rear duals concentric.
Spare's was MIA at time of purchase, but I've got one on the way...
Cool... do the slots in the rims have a purpose?
I was just at NAPA picking up the BHAF and was so excited it was under $40, completely forgot that I needed a couple of 5/8" tapered lugnuts!
I marked the right front tire (worst ruout) at the high and low areas. I rotated the high area in the tire to the low spot (valve stem) on the wheel (in my case, about 100deg). It cured 85% of the problem. I still have some vibrating at 58-62mph, but I am above or below that 90% of the time, so it isnt a big deal. From 40 to ~58, and from 65 to 80 it is smooth as silk.
I'm irritated that I didnt think of this months sooner.
DP
DP
If you want to try the slipping the tire on the rim trick, you don't need a tire shop to accomplish it.
Mark the tire at the valve stem.
Let out all the air.
Lay the tire/rim under the rear bumper of the truck, or the frame of a bull-dozer, or anything else heavy.
Set the base of a jack (preferably a HandyMan, but any kind of jack will do) on the sidewall, such that the long edge of the jack is lined up next to the rim of the wheel.
Apply jacking pressure until the tire bead gives.
You may have to do this in two or three spots around the tire.
When one side breaks loose, flip the wheel over and do the other side.
When the beads are loose, simply spin the tire 180* on the wheel and re-inflate.
It took longer to type the instructions than it will take to do this.
Daniel, do you use cone nuts to line up the wheels when you put them on? It sounds like you haven't been doing that. Our wheels are neither hub-centric nor lug-centric. The only way to get them centered on the hub is to run a couple of cone shaped lug nuts on, put on 6 of the flanged nuts, then remove the cone nuts and put on the last two flange nuts.
I know it sounds kooky but it's in the owner's manual.
What year did they start this??
I looked in the son's 1990 owner's manual, and no mention anywhere about the conical nut trick.
I know most older Dodge DRW tons, with the coined wheels, have CONICAL/ACORN nuts from the factory; in fact, a 1st Gen. Dodge/Cummins was just in the shop, Friday, and it had conical/acorn nuts, and not the flanged type.
I have no idea of it's year-model, as the grille, and a few other un-necessary parts, were missing.
The older Fords, with the coined wheels (which are identicle to coined Dodge wheels), all have conical nuts, not starting the flanged nuts until they started the flat-surface/un-coined wheels that are hub-centric.
Chevrolet/GMC started using hub-centric way back in the sixties.
A dead give-away to a wheel being hub-centric is, after the wheel has been on for several months, you have to crawl under the truck with a sledge-hammer and knock the wheel loose from the hub, before it will come off.
I have even had to install the nuts loosely and lunge across the parking-lot, slamming on the brakes, several times, until the rust breaks loose, permitting the wheel to come loose from the hub.
One more reason to use plenty of never-sieze.
Not all, but many, tire manufacturers have little round DOT stickers, usually yellow or orange, sometimes red, on the sidewall of new tires.
This dot-sticker is supposed to be oriented to the valve-stem, before inflating the tire, to achieve optimum balance.
I don't see the little stickers as often as I used to; and, due to the rough and tumble handling that tires get before the dealer gets them, a lot of the time the sticker gets misplaced/lost.
I have never actually mounted a tire with the sticker in various locations to see if it actually does make a difference.
Maybe sometime when we aren't knee-deep in customers, I will experiment with this sticker business and see if it actually means anything.
I didn't check the wrench size of front-versus-rear.
This truck has SOLID flanged nuts.
The nuts on my Ford, and ninety percent of other trucks, has the flange a seperate piece, sort of swaged onto the back of the nut, such that, when the flange contacts the wheel surface, the flange quits rotating, remaining stationary, while the nut tightens.
In the case of the solid flanged nuts on coined wheels, it would appear to me that a much better set-up would be the older style conical nuts, negating the need for all this wheel lining-up nonsense.
Also, I would think that, without the wheel first being anchored by four conical nuts, those solid flanges would have a tendency to "walk" the wheel around, as they were being torqued.
I have had 4 1stGen duallies, and they ALL had the 1-1/8" nuts, solid flange, on 5/8-18 studs. Wanna, I think your truck has some non-OEM nuts (excluding the one behind the wheel). 1-1/16 sounds like an older Ford setup.
Bearkiller- I had installed the little yellow dot facing the valve stem, and it wasnt the high spot in the tire. It may just be this particular tire/wheel combo, though.
DP
DP
As to Wanna's front nuts, my 85 F-350 does use 1-1/16 wrench for the nuts.
I never gave any thought to the thread size; maybe they are 5/8".
I am going to check into that.
Daniel, do you use cone nuts to line up the wheels when you put them on? It sounds like you haven't been doing that. Our wheels are neither hub-centric nor lug-centric. The only way to get them centered on the hub is to run a couple of cone shaped lug nuts on, put on 6 of the flanged nuts, then remove the cone nuts and put on the last two flange nuts. I know it sounds kooky but it's in the owner's manual.
