Thread Tools | Search this Thread | Display Modes |
#1 | ||
Vibration at 30-40 mph, changed center bearing
#2 |
Joe,
It could be the u-joint right behind the steady bearing. I have seen these seize on one trunion only, and cause all worlds of havoc. Also, if it is a 4x4, check the CV joint on the front shaft. The 2002 didn't have the axle disconnect on the front, so the forward shaft turns all the time, and wears out prematurely.
__________________
01 2500 Q/C 4x4, factory order HO w/5spd, 4 wheel discs, Pacbrake, 285 nitto HD grapplers on 17" eagle 186. Ultra 5th wheel hitch. Glacier Diesel GFS-392 LP 01 F550 XLT 4x4, replaced by a fleet of reliable mid 90's gmc trucks, with 6.5 diesels and 5 speeds. Old, slow and in denial, just like me... |
#3 |
Sorry I did't mention, but it is a 2 wheel drive. Also, the U-joints felt good except for the rear one that I changed out. Thanks, Joe.
#4 |
That is exactly what I meant. they feel just fine, but the one behind the steady bearing is busy becoming one as such.
#5 |
Thanks, will look into it. Joe.
#6 |
If the u-joint has play between the ears of the pinion yoke, the yoke has wear and should be replaced. I would replace the straps at the same time so everything fits snugly and won't move around once it is tightened down.
__________________
1996 Ram 2500 Club Cab, 4x4, 5 speed, KDP tabbed, Prodigy, Silverstars with relay kit, BD 4" cat back, Autometer gauges. |
#7 | |
Quote:
the end caps should be seated against the tab/ears on the yokes.
__________________
2002 6-SPD LB 4X4 QC BD 64/71/14, SB-DD3600, TST PM3/SMARTY MACH 4'S, RINGED W/ STUDS,HAMILTON BIG STICK,SPRINGS AFE/2 " 5" EXH D/PRICOL GAUGES, FASS 150, FUEL-STRAW, BORG BOX AND SHAFT, DSS-BOX DT PRO-FAB TRAC BAR, 3RD GEN UPGADED STEERING,DUNKS TRACTION BARS, AIR BAGS,17'' KMC'S, 37" TOYO MT'S 6" LONG ARM LIFT.THANKS RIP@sourceaumotive. US.MARINE PROUDLY SERVED 1993-2006 -NO BETTER FRIEND NO BETTER ENEMY- |
#8 |
Any chance your tires might be flat spotted due to sitting for a year? Just a thought.
__________________
2001 2500HD 4X4 QC SHORT BOX, C.T.D, STOCK, NITTO TERRA GRAPPLERS 305/70R16E |
#9 |
6 brand new tires, balanced, and wheels checked for out of round before mounting and balancing.
Put it on a lift and got it up to 35 mph and the drive shaft close to rearend started vibrating. Pulled it and we decided that the yoke is bad. Also have a little movement on where the rear part of drive shaft goes into the front tube at the center bearing. Will probably have to replace drive shaft and yoke. Anyone have a yoke I can use???? Thanks, Joe. |
#10 |
The u-joint not fitting the yoke is definitelly wrong. It is possible the wrong u-joint was installed two times. Not likely the yoke is causing looseness.
__________________
2008 1/2 3500 dually that is stock except for 2 micro inline filter for fuel. Infero red extended cab, long box made for highway towing. |
#11 |
The U-Joint is correct, but worn at the tabs. What may be causing the vibration could be the driveshaft. It was hard to seperate at the center bearing. Had to beat it out. The blue plastic coating on the spline was there, but some was torn. Put grease on it and reinstalled it. If I get looseness at the splines, do you think this could be cause of the vibration?? May need a driveshaft. Yoke will have to be replaced, I think, because of the tabs being worn. Suggestions??? Thanks, Joe.
| Display Modes | |
