Go Back   Dodge Diesel - Diesel Truck Resource Forums > 1st and 2nd Generation Ram - Years 1989-2002 > 1st Gen. Ram - All Topics
Register Forgot Password?
Search
submit to reddit
Thread Tools Search this Thread Display Modes
Old 06-27-2005, 08:44 PM   #1
keithplacervill
urgent help needed
was working on my fuel pin now truck starta great when i give it fuel it dies i had the throttle apart,pushed in fuel pin put back together and now doing this maybe t.p.s.
__________________
93' 4x4 auto stand cab. hx35/14cm banks bighead,tweeked pump, hole filled air box,transgo shift kit,boost gauge,pryo gauge,3200 gov spring and air bags all 4 coners with holding tank for front under front bumper
keithplacervill is offline   Reply With Quote
Old 06-27-2005, 08:48 PM   #2
smokNjoe
smokNjoe's Avatar
read the other thread you posted and try that
joe
__________________
real trucks rattle :D
92 w250 4" exhaust, gauges, factory tac, pump maxed, pin ground, bhaf
01 dodge 2500 24 valve 4x4 6 speed gauges, 5" exhaust, bhaf, supper-chips programmer, boost fooler, silencer ring mia, 2" lift soon to be a lot more :D
smokNjoe is offline   Reply With Quote
Old 06-27-2005, 08:51 PM   #3
keithplacervill
i already did that that is what got me here is ther a way to check the tps volts
Old 06-27-2005, 08:57 PM   #4
smokNjoe
smokNjoe's Avatar
not sure on the tps one more thing i would check is the fuel filter my did the same it would idel fine but when you got on the go peddel it would die i sat on the highway for 6 hours i changed the fuel filter and the lift pump and that fixed it. also check for air in the lines.
Old 06-27-2005, 09:04 PM   #5
keithplacervill
it only did this after i took off throttle that is why i ask about t p s because it reads off the allen head i took off to get to the screw for the pin
Old 06-27-2005, 09:06 PM   #6
smokNjoe
smokNjoe's Avatar
ok i owen a manual so i have no idea on the tps sorry and good luck
joe
Old 06-27-2005, 10:15 PM   #7
gman07
gman07's Avatar
I doubt it would be the TPS. I had a problem with the TPS sticking, causing the throttle to stick (idling along at 45 mph ) but I dont think the TPS would cause the truck to die.
Heres a site to check the TPS voltage (I set mine at around .7 VDC at no throttle): http://www.piersdiesel.com/Tech1GTPS.htm
The TPS only controls the 3-4 shift though, so I really doubt it could cause the problem you are describing.
__________________
Tom
9 diesels in all, 7 Cummins: 2 5.9's, 4 8.3's, 1 ISX
______________________________________________
1992.5 W250 pump tweaked, 3200 Gov. spring, AFC lever ground, timed at 1/8", BHAF, HTT Stage IV H1C/E 60/ported 12wg, Transgo shift kit, 230k
gman07 is offline   Reply With Quote
Old 06-27-2005, 10:19 PM   #8
keithplacervill
i just cal. my tps not the problem as stated still have no idea what it would be
Old 06-27-2005, 10:21 PM   #9
timb
I dont think that your tps would make your truck die, di you pull the bost line off to get to the fuel pin. if so, did you get the banjo washers back on. just a thought.
__________________
Mine,92 ext. cab 4wd, fuel pin,3200 gov. spring, htt62/14 turbo, ddp stage 4 injectors. really big air filter, 4"exhaust with 5" stacks, borgeson shaft, 1 ton rear wheel cyl. .pump timing tweeked, o-ringed head,hasely head studs.full dtt trans. with 91% torque converter.2nd gen. lift pump.321/866 last dyno.
also a member of the pull cable crew.
Her's, 99 std. cab 4wd. 3 Guage pod, egt, boost, fuel preasure.3" over stock rough country front shocks, leveling kit.
timb is offline   Reply With Quote
Old 06-27-2005, 10:26 PM   #10
keithplacervill
i took off the big allen that holds the arms on the pump which has to pieces and a spring .that the linkage conects to
Old 06-28-2005, 03:58 AM   #11
timb
In that case you did not mark where they were when you took them off. the linkage goes on a splined shaft, when you put it back together you got the linkage indexed wrong. if I'm not wrong, you need to take the linkage back off and move the linkage towards the front of the truck one spline at a time until it idles right. be ready to shut the truck off in case you move it the wrong way to much cause it will idle high if you do. I'm not real good at explaining things, so I hope this helps. good luck.
Tim
Old 06-29-2005, 08:59 PM   #12
keithplacervill
to the lasts rep. that is what it was thank so much when i was looking for help on the computer i found a recall and full instuction on how to change the pump the dealer said that they would still warr. if your truck is one of them the site is htpp://dodgeram.info/tsb/recalls/605.htm
submit to reddit
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.6
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
vB.Sponsors
Copyright 2011, DieselTruckResource.Com
Contacts Backup
