#31 | |
Quote:
Great post Dave! Thanks for your input on that. -------- John_P
__________________
Red Ram Rocket Scheid Diesel Tuned Pump, Scheid Twin Turbos, Scheid Arias Pistons, Scheid Cam and Ported Head, FASS, Scheid Water Inj.,Fluiddamper,ATS Stage V Auto Transmission in a 96' Dodge CTD Ext.Cab 4X4 (Best E.T.11.42-Coastal Plains Dragway, J'Ville, NC (10/12/08) Best MPH: 11.42@119.4 MPH (Coastal Plains Dragway,J'Ville,NC (10/12/08) 891/1585 TQ. "Fall Brawl", Oct.2007, Pa. 889/1343 TQ. "Western NC Dyno Day, 06/21/08 ------------- 2006 Flame Red 2500 Quad Cab, SLT, SRW, 4X4, Thunder Road Package, DiPricol "Optix" Gauges, TST PM 3 CR w/R-49, Smarty, Schwitzer 62/12, ATS TripleLok Stage V Auto. 460 H.P./845 TQ. (03-10-07) 580 H.P./1030 TQ.(12-18-07) Done with Smarty Beta 13.1@105 MPH (CPD, J'Ville, N.C., 04-26-07) Vice-President of NCDTR Chapter #18 |
#32 |
SOooo seems we could take our board apart ant check for continuity and re solder ...
__________________
1998.5 4 wd 1 ton dually. Ceramic topped , molidium skirted pistons, Eng. balanced to "0" grams No plastic oil .cooling jets here !! a big bad S.bend clutch to match the Mercedes 6 speed... UMPH! gauges, 275 inj. Bigger steer box, track bar and on and on and on.... Air bags on the rear and a fisher snow plow on the front. I do not know nothing and can prove it.! Will Plow for Beer ! Juneau AK. |
#33 |
Have you ever wondered why VW doesnt suffer from the same problems with their bosch VP pumps. They probably have more heat cycles then the Dodge truck seeing as how they are a passenger car.
#34 |
Now thats a good PT !!
#35 |
it took aftermarket makers 10-12 yrs to solve gm 6.5 pump drivers [electonic{ to solve there problem,the 6.5 was like the vp44 and could fail anytime without warning.maybe someone will fo the same for vp44,s
#36 |
We can only hope!
#37 | |
Quote:
![]() rob
__________________
99 2500 24V AUTO 89k miles / BFG 285/75R16 / Suspension MAXX Sway Bar LINKS / AFE Filter / EDGE EZ / EDGE Boost Elbow / Perma-Cool Fuel/Water Separator / Holset HX35 / Quadzilla RECON XZT boost/tranny / Silencer RING Removed / BlacK grille inserts / Pacer Hi-Five / Manual High Idle / Love Diesel Smoke!! |
#38 |
I know John Deere used the VP-44 on some of there tractors, not sure of the failure rate though.
__________________
01 2500 QC, 4x4, SB, 3.54, 47RE |
#39 |
Would it be practical to do a pre-emptive replacement of the timing sleeve & the computer on a vp44 that ISN'T acting up? How much would it cost in parts & labor?
__________________
2001.5 Cummins 2500 HD 4x4 Quadcab shortbed auto DTT rebuild + billet input circa 10/07 with Airtex gearotor type LP in Vulcan big line relocation kit, EZ Edge, 5" exhaust, & Nitto Terra Grappler 285's |
#40 | |
Quote:
Got a lot of ISB's in school buses and such that see the exact same issue....even heard of a internal memo @ Cintas's Repair facility concerning lift/injection pump failures. SO not just us Dodge boys (that are gluten's for punishment) that are having issues....wish i could say our pumps were an end all to VP issues (I have had 2 on my truck going on 3...1st fuel pressure related back in 04, the rest comp board (2nd) and IAT sensor (Current and 3rd))...but lack of fuel pressure is just one of the many ways for these things to die.....
__________________
Dan MacDonald '02 Jetta TDI 5 Speed "Mini Me" |
#41 |
I honestly believe that fuel pressure has alot to do with it. Most guys will say no more than 15, no less than 10. I've been running 20+ for 60,000 miles & my vp is still going strong [knock on wood].
__________________
99 QC 611hp/1141lbft with Cracked HTT manifold Big Thanks To: Peter @ Southbend Clutch http://www.youtube.com/watch?v=XmQhCXQbedg |
#42 | |
Quote:
![]() RJ
__________________
02, 2500, QCLB, 4x4, Auto, 3.55 Power-Lok LSD - DTT/Billet - Smarty/Pulsed Adrenaline - Mach 6's - BD Twins - Snow's H2O/Meth - FASS - F-1 Cam/Valve Springs - HTT Manifold - LazarSmith Bars - TC Lockup Switch - RAD - 3rd Gen Brakes - Fluidampr - DSS - 315/70/17 Pro Comp Xtreme A/T's Best Dyno - 628 HP/1266 ft-Lbs. Best 1/4 Mile - 12.72/105.94 - (7460 lbs) |
#43 |
I just replaced the VP44 on my truck two weeks ago. The truck had 66,000 miles on it and I had used a fuel additive from day one; either Amsoil Diesel Concentrate or Stanadyne. Apparently the electronics were ok, it was the housing that was worn out. Anyway, I bought my reman pump from M&D Distributors in Dallas and put it in myself. M&D is an authorized Bosch service facility and their pumps come with the following new components as well as all the Bosch updates: Pump Housing; PSG (the electronic control for the pump itself);Timing Piston; Head and Rotor; and Internal Supply Pump. In addition all bearings, seals, gaskets, etc. are replaced. Their remanufacturing facility is in Houston, TX. Their pump has a one year, unlimited mileage warranty which is pretty much standard. There are two issues that will nullify the warranty, (1) no gas and (2) no water. I was told these were Bosch issues as well so that's probably industry standard.
Anyway, I hope this pump will last much longer, mileage wise at least. It did hang on for 7.5 years though. I'm still running a Carter LP on the frame rail but with the fuel system mods that I’ve made to the truck, fuel flow restrictions shouldn’t be an issue. I guess it will boil down to the quality of the remanufactured VP44.
__________________
2002 2500HD QC Laramie SLT SB; 2WD; Auto; 3:54 AS; Camper/Tow Pkgs; 4" Exhaust; Optima Redtops; Bilstein shocks; DSS; Isspro EV 30psi mechanical FP gauge; Vulcan 3/8ths LP relo kit from tank to VP44; Centramatics Wheel Balancers. Mag-Hytec diff cover & tranny pan; Vulcan 3/8ths DS; I Replaced VP44 March 10, 2009 @66,000 miles. |
#44 | |
Quote:
#45 | |
Quote:
EB....you did good with your VP going to 62,000 miles. On my now sold 2002, my first one went out at 22,000 miles! Like alot of the other Members, I also had an aftermarket fuel system, bigger lines etc. |
| Thread Tools | |
| Display Modes | |
