| View Poll Results: Which type of TV? | |||
| LCD |
83 | 86.46% |
| Plasma |
13 | 13.54% |
| Voters: 96. You may not vote on this poll | |||
Thread Tools | Display Modes |
#31 |
i have a friend that works at wal mrt electronics he said when i was looking for a new tv that vizio has the least returned out of all that they carry
__________________
96 3500 ex-cab srw conversion 5 spd 4:10's boost elbo bhaf,lukes link, silencer ring in the trash . nerf bars straight pipe. 290,000 miles kdp killed sunpro gauges, marine 370's 15.5*timing #11 plate full forward 2006 Harley Davidson softail with lots of goodies Have you ever noticed? Anybody going slower than you is an idiot, and anyone going faster than you is a maniac. 1991 vw jetta turbo ECOdiesel |
#32 |
Chief Operating Officer
If you do a little research on line about the plasma tv's you will not spend your money in that direction
__________________
Chief Operating Officer Diesel Truck Resource LLC To start a local chapter of DTR in your area email chapters@dieseltruckresource.com lellis@dieseltruckresource.com 304-952-6896 DTR Performance Shop Toll Free USA 1-877-375-1956 This country has come to feel the same when Congress is in session as when the baby gets hold of a hammer.-Will Rogers |
#33 |
i have a sony xbr 9. i like it, great picture and little to no artifacting/ ghosting.
__________________
92 w250 le 110k Lincoln classic 300D 07 3500 megacab laramie Parts swaped, added, moddified and/or deleted from both |
#34 |
Research the High End Plasmas, it will be worth your time
Through a lot of research I have found that most people are very ill-informed on the pros and cons of both types of sets. As the technology has gotten better in both sets, the prominent problems with each type of sets have become less and less noticeable or have gone away all together.
I too first bought into all the LCD is better hype. I bought a Samsung LNT-4071F in early 08 (which is a 40" 1080p 120hz set with CCFL backlighting). It was a great TV and still is a really good TV but as it has gotten older then blacks have become less black and I noticed that the backlighting is not very even and almost blotchy in very dark scenes. EVERY LCD TV with CCFL backlighting I have seen eventually develops this problem to some extent. Sometimes you can barely notice and sometimes it makes the TV unwatchable. I thought at first maybe it was just my 40" unit so when I wanted a bigger TV I bought a Samsung LN-52a650 (which is a 52" 10080p 120hz set with CCFL backlighting) It had the same problem mentioned above very bad right out of the box and so did its replacement, so I got rid of that and started researching the TVs with LED backlighting and plasmas. After more research than I ever wanted to do I ended up with a Pioneer Elite Kuro 50" Plasma. MSRP $4,449 (but Best Buy had mistakenly marked the unit at $2,499 so I bought it on the spot) In my opinion and that of Cnet as well this is absolutely the best picture you will find on any TV period. See for yourself. I know JFaulkner knows what I'm talking about. http://reviews.cnet.com/flat-panel-t...?tag=mncol;lst If you read this much I would recommend a high end plasma if you are really interested in the best picture quality and deepest blacks, and you can afford it. If you want to stay a bit cheaper, buy an LCD TV with LED backlighting, not CCFL. The LED backlighting will give you much better blacks and help the colors of the LCD "pop" a bit more. With that said I would stay away from units where the LEDs create the backlight from the sides of the TV (like Samsung's line of so called LED TVs which are actually LCD TVs) and get one where the LEDs are directly behind the panel (Something like a Samsung LN55A950). I would highly recommend to stay away from a set with CCFL backlighting with all the excellent other choices out there. For image refresh rate 120hz seems adequate but if you can get 240hz for a good price go for it, but I don't think there is really much difference the average person will see past 120hz. If you buy a plasma of course this doesn't really matter. The Pioneer Elite KURO plasmas adjust their refresh rate to the input source. Hope this helps somebody. ![]()
__________________
Silver 2005 Ram 2500 4x4 QC SWB CTD NV5600 3.73, KORE RECON, 35" TOYO MTs, Buckstop Baja Bumper, Pacbrake Airbags, Putnam Class V XDR, 14k Equalizer Weight Distribution Hitch, Straight pipe, Line-X bed, UWS black powerdercoat toolbox, silencer ring MIA, prodigy brake controller. 92 YJ Wrangler with 5" susp lift and 33" BFG Mudders, Full 6 point cage, Black Line -X tub and Red Durabak bedliner exterior. Trailer is a 2008 30 foot tag along enclosed V-nose Horton Hauler with two 7k axles. |
#35 |
Vizio is supposed to be releasing their 55" LED next week.
__________________
'99 3500 SPORT BlackClick for Picture Gallery DTR Site Moderator |
#36 | |
Quote:
__________________
06 2500 Big Horn 4x4, Quad cab, SLT, Flame Red, S&B Intake, Banks Monster Exhaust, HTS Valvebody. Leaders stand out,not alone... Not a member of the over compensating club....(AKA Megacab Club) |
#37 | ||
Quote:
Quote:
I looked at a Samsung today with the Automotion 120Hz sampling. They were scrolling text across the bottom of the screen and the difference was EXTREMELY noticeable between having the sampling on or off. But what exactly is the Automotion sampling doing for you? Is it just a 120Hz refresh or something different?
__________________
Maroon 2001 2500 QC 4x4 SB SO pumped HO 6-speed 285/75R16 BFG Mud Terrain T/A KO, Smarty, TST Powermax3, KSB1-1, DD2s, Autometer EGT/Boost, Westach Fuel Pressure, Amsoil EaAU4091 |
#38 |
I picked up the Vizio 55" 240hz LED at Costco for ~$1800 the week before Christmas.
(Merry Christmas to ME) The picture is very nice, at a price ~$1000 less than the Samsung. The Samsung IS only 1/2 inch or so thick, the Vizio is about the same thickness as the Vizio LCD version. (But I don't plan on watching the SIDE of the tv. ) |
#39 |
Just the opposite. Faster refresh rate makes them smoother. You ever notice when you see a computer on TV (newsrooms on the news are the ones I've seen most) how you can see a black bar move up the screen over and over like the old TV's that would roll if the signal wasn't just right? Monitors refresh more slowly (mostly 60hz). You will notice it the most with crawlers on the bottom of the screen (weather info, etc.) They tend to get choppy with the slower refresh rate.
__________________
My Truck: 1996 2500 4x4 5-speed K&N Filter and Straight Pipe, Silencer Ring Removed, AFC modified, 201K 4x4 posi-lok (best money spent), power window mod Wife's 05 Jetta TDI |
| Thread Tools | |
| Display Modes | |
