#1 |
Turbo Housing Question
I just discovered today that one of the exhaust housings off of a 4bt we are parting out is a 16cm housing. Would that fit on the stock turbo that is on a 1st gen? I'm planning on installing an intercooler soon and was wondering how much turbo lag that was going to add charging up all that extra tubing and how much boost drop i might have. I didn't know if it would be worth saving this housing to put on my truck??? I've got and 18.5 housing on the truck now.
__________________
1990 D-250, Getrag overfilled, 3.54, Tweaked Pump, BHAF W/4" custom intake , Stans 4" w/straight pipe, Autometer Gauges, Air Lift Overloads, Amsoil in Everything, Homemade Front Bumper, Borgeson Steering Shaft, Eagle Alloys, KDP KILLED, 1/8 Timing Bump, Gillett 60mm compressor, 12cm w/g exh ported, 366 spring, 3" Crossover, Denny T Stage II, 22 MPG, Banks intercooler coming soon! |
#2 |
i would definitly go with the 16 over the 18.5 on a g-rag
__________________
1990 w-250 430,000km 727 1400 stall tc, pump mods,3 1/2 turns, bd fuel pin, 4inch dp to 5 inch dual stacks 274 hp, 644tq on a 1500hp chassis dyno |
#3 |
Any other thoughts anyone?
#4 |
16 would provide some spool improvement, but not really worth the work, IMO. If you're not going to a 12 w/g (my personal recomendation) then leave well enough alone.
__________________
'96 2500 club cab 4x4 5 speed 2'' leveled autometer boost/pyro 215 pump, timed at 16.5* zero-ish plate, 4kgsk South Bend 3250 street DD clutch Yokahama Geolanders, 315 70 17's on H2 satin wheels 12.5k Warn winch lots of rust, lol! Formerly: '89 w350 5-speed. Mods-3rd gen IC, HTT III |
#5 |
I disagree. I noticed a significant difference going from an 18.5 housing to a ported 16 housing. It brought the boost up 5 to 10 PSI.
__________________
1990 W350 5.9L CTD G360 GV O/D 3.54:1 255K Cast Elbow to 4" 2nd gen DP to 4" Magnaflow to 5" tip, BHAF, 366 spring, DennyT StageII Fuel Pin, 16cm, 60mm, 3" Crosspipe, Custom fuel filters (10, 5, 2 micron), Isspro EGT, Boost, Tach, 12K winch, double tube rollbar with 6 x KC Daylighters (800 watts total) - Dyno 214/520 w/ pump detuned 1979 Li'l Red Express 360 4BBL 1974 Duster Super Six 1970 Challenger R/T Clone 1970 Charger Daytona Clone 1970 Charger 383 2001 BMW 750iL 2009 PT Cruiser |
#6 |
i love my 16cm spools super fast imo
__________________
1993 power ram 250 4x4 5 speed 6in skyjacker lift,35 mickey tompsons, 4in turbo back and 6in turnout stacks with ddp fuel pin and hx 35/40 hybrid and also a afe cold air intake and the afc turned down, and a set of bully dog pyro and boost gauges, pods,pump tweaks by wanna diesel, bumped timing, sb ofe, |
#7 |
I agree here also... Not worth the money, if its free, sell it to somebody with a 21cm.
__________________
90 w350 DRW Getrag, 3.54s- alive 1994 dodge 2500. 47rh. 1984 k5. 6" lift, 38s. 1979 Camaro. 11.31@122 Street trim. |
#8 |
How would a 14cm wastegated housing work?
#9 |
Ad-meany-strator
It will work pretty good with the stock injectors. Don't pay much money for it though, you will outgrow it quickly if you add more fuel.
__________________
'93 D350 - DPS 6x16's, HTT Stage IV/14wg, PowerStroke IC, Snow water/meth, Walbro 392, Con-FE, pump tampering by owner. 386 HP/774 TQ on #2 only, 408 HP/844 TQ w/ water/meth - needs more air! "Butterscotch" - '82 Mercedes 300TD Dead KDP's = 72 |
#10 |
#11 |
Not plannin on runnin any more than stock injectors. It's got to be able to tow over 10k when i need it too without burnin up.
#12 |
| Thread Tools | |
| Display Modes | |
